Author Topic: Swingarm Bushing  (Read 1008 times)
Offline rocco
Swingarm Bushing
« on: March 13, 2016, 04:14:57 PM »
Hello,
I was installing a new hard plastic swingarm bushing by what I thought was pretty easy tapping with a rubber hammer and block of wood. I got the bushing in half way and realized that I have a small crack in the lip of the bushing, the part that is outside of the swingarm.
Noob question, but is the bushing finished? Does the lip on the outside fill a necessary gap that would cause side to side movement of the swingarm? I know a lot of you use brass bushings, but I had these lying around so I thought they would be fine, guess they're much more fragile than I thought.
1978 Honda CB550K.
"It is vain to do more with what can be done with less" - William of Occam (Occam's Razor)
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Swingarm Bushing
« Reply #1 on: March 13, 2016, 06:15:59 PM »
Hello,
The lip provides a thrust surface to keep the sing arm from sliding side to side. A small crack may not pose a problem, but any more than that and I would replace them.
.........Paul
Wear a helmet,the life you save may be your own.Ask me how I know.               CB650C,CB550F,GL1000,CB750A
Offline rocco
« Reply #2 on: March 13, 2016, 06:38:37 PM »
Thanks Paul,
I figured as much, I'll order the bronze ones, cheers
1978 Honda CB550K.
« Reply #3 on: March 13, 2016, 10:42:53 PM »
Kenosha Kid has the best prices. He also has great price on the allen head engine bolt kits too.
Offline rocco
« Reply #4 on: March 14, 2016, 07:44:07 AM »
Cheers Jerry, if I had seen the prices on his bronze bushings I would have never bought this damn plastic ones in the first place. I will make sure I press these ones in.
1978 Honda CB550K.
Offline Powderman
« Reply #5 on: March 14, 2016, 10:48:48 AM »
I have 1 set left for $35 if you're interested. Doesn't look like KK has any on EBay right now.
Offline rocco
« Reply #6 on: March 15, 2016, 11:20:33 AM »
Hey Powderman, he may have run out after I got mine! Or maybe they're different for a 750, I have a 550.
Thanks,
Reilly
1978 Honda CB550K.
