Author Topic: Is this brake piston any good?  (Read 1024 times)
Offline Nayl
« on: April 09, 2016, 07:03:06 PM »
Bought a rebuild kit for the rear brake on my F1, which included two stainless steel pistons.  Pistons came packed loose together inside a plastic bag, which probably accounts for the various small divots in the working surfaces.  These aren't huge, but it seems to me that they are going to cause the brakes to leak constantly as the pistons fail to mate with the seals.  Am I wrong?
Offline MoMo
  • Ride like you're invisible
Re: Is this brake piston any good?
« Reply #1 on: April 09, 2016, 07:11:24 PM »
Are those indentations I see?  If so, I"d can it
Offline Nayl
« Reply #2 on: April 09, 2016, 07:14:42 PM »
Yep, there's a diagonal one about 2/3 of the way up, and a horizontal one at the midline.  Hoping the Ebay store I got this from will do the right thing on this.  Not the first time I've had issues with ebay parts, but this will definitely be the most expensive piece of junk I've bought.
Offline Trad
« Reply #3 on: April 09, 2016, 07:39:00 PM »
Can I ask what vendor packaged those? That's a bummer though.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline tlbranth
« Reply #4 on: April 09, 2016, 07:56:40 PM »
You are not wrong. Return the pistons
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #5 on: April 09, 2016, 11:53:18 PM »
geez...really gotta wonder how stainless got dented so easily?...that #$%* is supposed to be hard
Offline Nayl
« Reply #6 on: April 10, 2016, 04:35:23 AM »
FYI, I got it from these guys - http://www.ebay.com/itm/HONDA-CB750F-GL1000-GOLDWING-REAR-BRAKE-CALIPER-REBUILD-KIT-1975-1977-/161913242984?vxp=mtr&hash=item25b2c80568
Big outfit, high ratings.  All it takes is bad packaging, unfortunately.  The ad describes the material as "304 Stainless" which is the same stuff they make kitchen knives and cooking pots out of.
« Reply #7 on: April 10, 2016, 08:32:14 AM »
I got my kit from Sirius Consolidated also, just not on EBay and it was less expensive. It looked great. No problems. Hopefully they will swap you out. I'd be more concerned about the edges of the divots dragging in the bores, otherwise I wouldn't worry too much about leakage past the seal AS LONG AS the positioning of divot vs seal is good. It may be a non-issue.
Offline Nayl
Re: Is this brake piston any good? - Update
« Reply #8 on: April 11, 2016, 07:02:43 AM »
Got this message this morning -
Sorry about that, I'll get a new set of pistons out to you today!
Chris
Sirius Consolidated Inc
and already got notification from Fedex that its on the way.  Not bad.  :)
Offline MoMo
« Reply #9 on: April 11, 2016, 07:53:04 AM »
I've bought stuff from them and have experienced good customer service if there is a problem
Offline Powderman
« Reply #10 on: April 11, 2016, 09:24:20 AM »
Being as they are smooth shallow dents the seal would fill the gap and do it's job. The dents are far enough out that pad wear may have the dents exposed before too long. I would have done what you did and replace them anyways because you didn't pay retail fto get damaged parts.
