Author Topic: MC Connecting Rods and Cylinder Clearance  (Read 1453 times)
Offline SKOL
« on: April 25, 2016, 11:54:51 AM »
I've noticed that nearly all the aftermarket connecting rods I find come with the caveat that the cylinder skirts need to be notched to make room for the new rods. I've seen this done on a couple youtube videos (Hackaweek was very helpful). However I don't have access to a mill. Anyone know if this could be one by hand with a Dremel? Just keep slowly notching it down until clearance is met. Seems like this could be do-able unless I'm missing something. Thanks
Offline Swoop
Re: MC Connecting Rods and Cylinder Clearance
« Reply #1 on: April 25, 2016, 01:11:30 PM »
The notches on mine were about 1 1/2" wide and about 3/4" high...roughly from memory....that's alot of dremelling.
« Reply #2 on: April 25, 2016, 04:33:50 PM »
  He's notching the cylinders not the rods. A Dremel's a bit light weight but a die grinder could make some good progress.
Offline Swoop
« Reply #3 on: April 25, 2016, 04:38:43 PM »
That's what I was talking about.
Offline Dunk
« Reply #4 on: April 25, 2016, 07:01:20 PM »
Die grinder and carbide burr, then smooth edges with a stone on the die grinder. Dremel is probably a bit small of a tool for that job.
Offline SKOL
« Reply #5 on: April 26, 2016, 06:12:59 AM »
Thanks for the responses guys. I do have a die grinder, as well as access to a pretty heavy duty bench grinder with medium and rough stone wheels. The bench grinder might work out quite well, then use the dremel or the die grinder with a stone to smooth out the edges.
