Author Topic: Oil seeping from bottom of motor, Shifter cover bolts rounding!  (Read 1255 times)
Offline SierraCB
I seemed to have developed a slight oil seep from the bottom right of my motor, right around the forward area of the shifter.  Guessing that it could be a seal, I broke out the original toolkit phillips head (JIS) only to find that all the heads want to round off and not turn.  Any way to get this out and not totally ruin them??
Also the oil seems to only happen when I turn the bike off, it is not happening consistently after being parked.
Re: Oil seeping from bottom of motor, Shifter cover bolts rounding!
« Reply #1 on: May 17, 2016, 04:12:18 PM »
 You need to use an impact driver for the screws before you ruin them. One of the must have tools.
« Last Edit: May 17, 2016, 04:21:44 PM by ekpent »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: May 17, 2016, 06:38:00 PM »
I'm a fan of using a small blade to make a phillips into a flat slot when they get too far gone.
If it's a lot of oil seeping out, I suspect oil pump o rings.
Offline camelman
  • Man... Myth... Legend
« Reply #3 on: May 17, 2016, 06:43:33 PM »
You might be able to tap a philips impact driver bit into what's left of the screw heads, and then slip the impact driver body onto the bit. Then...whack away! (That sounds bad)
If that doesn't work, then I usually try the flat head next by cutting a slot in what remains of the screw head. Failing that, I drill the head off with a drill bit and replace with new hardware. Ace Hardware carries the screws and literally labels them "cheese head" screws.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #4 on: May 17, 2016, 08:32:14 PM »
An impact driver w JIS tips.. ;)
Offline theslayedsaint
« Reply #5 on: May 17, 2016, 08:38:26 PM »
JIS first time I've heard that! Is the Japanese heads different then USA?
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
« Last Edit: May 17, 2016, 08:53:17 PM by flybox1 »
« Reply #7 on: May 17, 2016, 09:01:34 PM »
You know us Americans we live under a rock...
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
« Reply #8 on: May 17, 2016, 09:03:04 PM »
I bought a snap on socket with a phillips tip that fits my 3/8" craftsman battery impact drill, it's removed almost every screw I ever tried it on. My theory is if you don't have jis, pick the phillips that fits best then go one size bigger. Whack it with a hammer if you need to or just buy the one pictured above.
Offline b52bombardier1
« Reply #9 on: May 18, 2016, 04:57:12 AM »
JIS is the way to go. McMaster - Carr also has a good set of three of these drivers. You can't work on a Japanese bike without all three sizes.
Before I learned about JIS,  I had to drill a few heads off and replace the screws.  Once the head is gone, you will likely be able to remove the shafts with just bare fingers.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline dusterdude
« Reply #10 on: May 18, 2016, 03:33:22 PM »
Get em out however you can the use socket head capscrews,screw phillips
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
