Author Topic: Dyna 2000 ignition problem  (Read 3150 times)
Offline H2Eric
« on: May 21, 2016, 02:04:43 PM »
I've been using a Dyna 2000 ignition system and covered over 2000 miles with no problem, but recently the bike (K9, you'll find a picture of it on this forum somewhere with one of Mikes billet cylinder blocks and a Bike of the month winner) has been cutting out on cylinders 2 and 3. This first started on a very hot day after a journey of around 10 miles. Leaving the bike to cool for a few minutes it starts up on all 4 and will run just fine for a while before cutting out on cylinders 2 and 3. I've checked for loose wires, but found nothing wrong. Could it be the coil that feeds cylinders 2 and 3 that's playing up? Anyone had similar problems? The Dyna coils in use are the gray ones.
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline jonnycakes
Re: Dyna 2000 ignition problem
« Reply #1 on: May 21, 2016, 02:36:14 PM »
I had a Dyna S that would cut out when it got hot.  One of the pickups went bad
'Matic-Fanatic
« Reply #2 on: May 21, 2016, 02:54:10 PM »
Swap your coils around and see what happens.
« Reply #3 on: May 22, 2016, 12:50:28 PM »
Eric
 I wouldn't use anything less than a 3 ohm coil unless you have Ander's charging system. Those gray coils are 2 ohm. Not saying that is the problem but just something to keep in mind. Like Jerry said I'd switch coils.
Offline turboguzzi
« Reply #4 on: May 23, 2016, 03:56:58 AM »
dyna failure stories are so common that i stopped counting the posts.... grab any 80's-90's 4 cyl igniton box + rotor + pickups. and you are sorted.
i use either GSXR (single pickup) or GPZ (double pickup) stuff on all of my 4 cyl bikes, race or street, never had a failure.
« Last Edit: May 23, 2016, 05:09:42 AM by turboguzzi »
