Author Topic: CB550 Carburetor Fuel Line Plugged  (Read 853 times)
Offline roberhow
« on: May 30, 2016, 04:19:38 PM »
Greetings,
I have a 1976 CB550 with Keihin carburetors. The fuel line that feeds carburetors 3 and 4 is restricted causing limited flow to carb 4. I have filled the line with carb cleaner. This fills float bowl 3 and maybe 25% of float bowl 4. They have recently been kitted, and everything looks clean inside. It appears there is a restriction between the "T" junction and carburetor 4, just my best guess. Looks completely inaccessible... any experience with this would be greatly appreciated.
Offline Bankerdanny
  • Endeavor to persevere
Re: CB550 Carburetor Fuel Line Plugged
« Reply #1 on: May 31, 2016, 07:45:58 AM »
The restriction is in the line that connects the two carbs, not the line that brings fuel from the tank. You can separate the carbs to clean or replace the connection. It's a pain in the ass to get the older carbs apart, but it can be done. Just take your time and take lots of pictures during the process so that you have a clear record of how to put everything back together.
« Last Edit: May 31, 2016, 07:47:40 AM by Bankerdanny »
  • I'm back
« Reply #2 on: May 31, 2016, 11:27:38 AM »
First I would simply blow air through the #4 float valve opening upwards after you've removed float and float needle*. Can be done with compressed air or even a bicycle pump. No need to separate carbs.
* Now that you're at it you can inspect valve and needle and maybe polish them very lightly, veeeerry lightly.
« Last Edit: May 31, 2016, 11:34:12 AM by Deltarider »
Offline Scott S
« Reply #3 on: May 31, 2016, 11:54:08 AM »
 Are you sure it's not the float height of #4 that's the problem?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
  • I'm back
« Reply #4 on: May 31, 2016, 12:52:13 PM »
That would make sense, Scott. If it gets filled for 25%, at least fuel gets true. For the moment forget what I wrote before for later and save it for later.
Could you be a bit more specific? Have you been 'adjusting' the float? Did you happen to use aftermarket parts?
« Last Edit: May 31, 2016, 12:56:58 PM by Deltarider »
« Reply #5 on: May 31, 2016, 02:53:03 PM »
What about the atmospheric vent preventing #4 from filling/equalizing as fast as the rest?
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #6 on: May 31, 2016, 03:41:29 PM »
and if you DO pull the rack apart, make sure you have all the right size o-rings to put it back together...
Offline roberhow
« Reply #7 on: May 31, 2016, 04:01:59 PM »
The number 4 float has been adjusted and even with floats 1,2 and 3. When I blow(just with my mouth) through the fuel line into carb's 1 and 2 it's much easier than with 3 and 4.
  • I'm back
« Reply #8 on: May 31, 2016, 11:39:45 PM »
You didn't answer my question about aftermarket parts. After you readjusted float #4, does #4 still fill insufficient?
Then check vent 3+4 first. If there really is a blockage in fuel line 3+4, I'd use my rubber airpump (to inflate rubberboats/mattresses) that also can suck (if it's tube is put in the other hole) and then suck fuelline 3+4 with it. Or blow air through the #4 float valve opening upwards after you've removed float and float needle. Can be done with compressed air or even a bicycle pump.
« Last Edit: May 31, 2016, 11:45:16 PM by Deltarider »
Offline alacrity
« Reply #9 on: May 31, 2016, 11:52:44 PM »
can also be done with a vacuum... try a hand vacuum/Dustbuster with something you can sleeve down the orifice to connect to a tube.
I have a "fitting" for my shopvac... one of the plastic extension tubes that has 3 decreasing diameter rubber tubes duct taped into the end of it - the final one is 3/8" id.  It makes a pretty strong highly localized pull.
