Author Topic: Oil tank connections K2  (Read 927 times)
Offline bahram112
« on: June 19, 2016, 12:40:02 AM »
Can anyone please help me?
Problem: I just bought a K2 from 1973, he is fully restarted. After  a short ride (some problems to keep the engine running) I discovered a lot of oil on the nearside of the motorbike.
I have opende the oil tank and I see that there are, next to delivery and return pipes, 2 other additional tube on the tank. Looking to the manual on this forum, one (the upper big one) is the " breather tube A" but I don't see anywhere in the manual what the lower/small tube is.
Can anyone tell me where this tube should be mounted to????? :-\
see picture (the picture is made from the other side and it shows the lower part of the backside of the oil tank.
Offline bahram112
Re: Oil tank connections K2
« Reply #1 on: June 19, 2016, 12:41:27 AM »
BTW: I have already discovered that the Oil level is too high. Still PLEASE help me to find out the purpose of the small tube...
Offline edwardmorris
  • Youngish
« Reply #2 on: June 19, 2016, 03:31:48 AM »
Offline bahram112
« Reply #3 on: June 19, 2016, 06:49:28 AM »
Thank you Edward!
Do you know if my engine ignition/running problems is related to missing of this hose? (the engine falls out when it gets warm)
« Reply #4 on: June 19, 2016, 06:56:36 AM »
 I doubt the running issues  are related to the oil leak. Also always check your oil after the engine has run before adding more.
« Last Edit: June 19, 2016, 07:04:05 AM by ekpent »
Offline bahram112
« Reply #5 on: June 19, 2016, 11:32:13 AM »
thanks a lot!
