Author Topic: Torque Spec Request for Honda CB500 (Intake Manifold)  (Read 2201 times)
Offline zerodaydave
« on: July 09, 2016, 09:00:08 PM »
Hey guys -
I've googled this and I've looked all over the manual. My bike is in pieces and I can't find the torque specs or bolt pattern for the intake manifold on a CB500. Help?
Offline Bootsey
Re: Torque Spec Request for Honda CB500 (Intake Manifold)
« Reply #1 on: July 09, 2016, 10:38:21 PM »
As far as I'm aware, there isn't any particular bolt pattern or torque specs for the 2 intake manifolds - just tighten the nuts firmly by hand. More importantly make sure the 4 o-rings in the manifolds are still supple, as they can tend to flatten & harden over time, which may lead to air leaks.
Offline flatlander
« Reply #2 on: July 10, 2016, 01:45:21 AM »
they're 6mm nuts. if nothing specific is described then the generic spec for "standard parts" on page 1 of the manual applies.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: July 10, 2016, 03:17:47 AM »
Yup
Offline Deltarider
« Reply #4 on: July 10, 2016, 07:29:51 AM »
Dave500:
ive posted this before and many others aswell,never actually torque any 6mm bolts down,it just doesent work,youll snap the bolt or strip the static thread every time!just feel them down then nip them up later once or twice with a strangled wrench,im surprised people are still torquing 6mm threads.
Why would you use a torque wrench for 6 mm bolts? No serious mechanic would ever do that. Use a torque wrench only where it is really needed and for the rest, maintain your skill to feel what force is needed. Oh and stop just before it snaps. ;D
« Last Edit: July 10, 2016, 07:33:29 AM by Deltarider »
CB500K2-ED Excel black
Offline flatlander
« Reply #5 on: July 10, 2016, 12:51:06 PM »
well not everyone is born with that feel. for those, it helps to use a torque wrench even on 6mm nuts so that they know how much is enough. usually people who don't know any better, tend to overtighten them.
  • Holy Cow! I'm a
« Reply #6 on: July 10, 2016, 01:24:42 PM »
I've had trouble getting a reliable 'click' out of torque wrenches under 15#
Reeeeeaaallllyyy wish I had a digital
Offline zerodaydave
« Reply #7 on: July 13, 2016, 07:33:30 AM »
Thanks man. I just followed your advice. Thanks for the pro tip on the orings. All is good.
