Author Topic: Which direction for fork seals?  (Read 4522 times)
Offline SKOL
« on: July 25, 2016, 02:33:19 PM »
Reassembling my front forks, can't remember which direction the fork seal faces. One side Is double lipped, the other flat. I'm assuming the flat side goes "down" toward the lower fork assembly but just wanted to check. Below is a picture of the double lipped side, I'm guessing this double lipped side faces "up".
Re: Which direction for fork seals?
« Reply #1 on: July 25, 2016, 02:40:07 PM »
The flat side with the numbers goes up, and the double lipped side goes down.
Offline SKOL
« Reply #2 on: July 25, 2016, 02:51:54 PM »
Well both answers so far are opposite haha
« Reply #3 on: July 25, 2016, 03:28:02 PM »
And only one of the answers is correct. ;)
« Reply #4 on: July 25, 2016, 05:19:05 PM »
Text/numbers up!
Offline Johnie
« Reply #5 on: July 25, 2016, 06:03:23 PM »
OEM seals? If so, like Stevo said text/writing goes up.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #6 on: July 25, 2016, 06:13:46 PM »
OEM or aftermarket, the text/numbers go up. I just got some aftermarket fork seals, and they are double-lipped on both sides! I've never seen seals like this before! The instructions say the text goes up, but it's very small as it's on the edge of the thin outer lip.
Offline przjohn
« Reply #7 on: July 25, 2016, 06:24:21 PM »
Open end with the spring showing goes down facing the inside of the fork. Normally a seal will be set with the open end showing the spring toward the liquid it is sealing in, think shift seal, k/start seal, crank seal, etc.
Offline SKOL
« Reply #8 on: July 25, 2016, 06:45:10 PM »
Thanks guys! Got the seals in with letters/numbers "up" and everything else in and buttoned up without a hitch!
Offline Mr Freeze
« Reply #9 on: July 25, 2016, 07:53:25 PM »
Sorry I messed up. My wording was supposed to be the side you're holding up goes in first.
Offline Johnie
« Reply #10 on: July 26, 2016, 05:14:54 AM »
Glad you got it sorted...
Oshkosh, WI  USA
