Author Topic: "Search" function does not work  (Read 2057 times)
Offline jmelche2
  • 1974 CB550
« on: August 10, 2016, 06:33:12 PM »
Does anybody know what's going with the search function?
Offline daniel9441
Re: "Search" function does not work
« Reply #1 on: August 10, 2016, 06:36:37 PM »
Mine is down too
Sent from my XT1585 using Tapatalk
Offline colvinry
« Reply #2 on: August 10, 2016, 07:04:22 PM »
Yeah tapatalk search blows. Use google and put "SOHC4" after your search terms. Then you can expand those results with a little link under the forum results and it will list all the results from the forum.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: August 10, 2016, 08:24:48 PM »
It's broken even without tapatalk. I noticed it a couple of days ago.
« Reply #4 on: August 14, 2016, 09:18:05 AM »
The search was too limited. The older google add-in worked fine. Possible to use "advanced" search expressions.
Google is the search engine today.
Just have SOHC Forums in the search and you'll find threads here.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #5 on: August 14, 2016, 10:31:19 AM »
It's true.  I searched high compression pistons and came up with zilch.
Offline Short shins
  • New Zealand
« Reply #6 on: August 14, 2016, 02:00:16 PM »
not working down here either.
I knew something was up when I searched "Oil" and got nothing  :o
I love sleep. My life has the tendency to fall apart when I'm awake, you know?”
Ernest Hemingway
Offline Scott S
« Reply #7 on: August 14, 2016, 03:48:13 PM »
 From Glenn: "Use the Google search method described by NobleHops for now.  I am in the process of rebuilding the site search index.  It is going to take a while - it is at 16% after running for around 6 hours."
http://forums.sohc4.net/index.php/topic,159945.0.html
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Short shins
  • New Zealand
« Reply #8 on: August 14, 2016, 04:15:09 PM »
Thanks for all your hard work guys much appreciated
MT
Ernest Hemingway
Offline m00ntan
« Reply #9 on: August 16, 2016, 12:36:21 PM »
Bump, Google will take over the world someday.
CB750K4
CB550K1
CM400C
« Reply #10 on: August 16, 2016, 12:48:32 PM »
I searched JW, JJW, JWilde, Leopard body suit.  No hits.
It aint broken!  ;D
Offline nicks2319
  • Youngstown, OH
« Reply #11 on: August 16, 2016, 01:27:47 PM »
Never used the search anyway, always used google. Syntax is :
search query site:forums.sohc4.net
Offline m00ntan
« Reply #12 on: August 16, 2016, 02:24:28 PM »
And someday you too will work for Google.
CB750K4
CB550K1
CM400C
