Author Topic: The Snail Carb Synch Tool... new source and info.  (Read 6563 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: November 29, 2006, 07:53:49 AM »
Anyone ever use one of these?  I was reading about them in Bike magazine the other day.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=010&category=43998&viewitem=&item=200043005192
Sparty
« Last Edit: December 01, 2006, 04:50:46 AM by sparty »
1972 CB750 K2 Cafe' Style
Offline heffay
Re: The Snail Carb Synch Tool
« Reply #1 on: November 29, 2006, 08:04:01 AM »
seems like it should work but, you still never get a constant reference while adjusting the other carbs.  single types like that can be a real pain in the a$$ on something with 4 carbs.
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #2 on: November 29, 2006, 10:50:08 AM »
Could you use 4 simultaneously?  I'm wondering if I could use it or a set of them to sync my CR29's, which do not have vacuumm fittings.  At the moment, they have only been bench sync'ed, and I will likely mount vacuum fittings; however, this might be easier.
Quote from: SOHC Digger, RIP
'77 CB750k
Offline heffay
« Reply #3 on: November 29, 2006, 10:55:23 AM »
well, if they seal off the intakes  ::)... not for very long
« Last Edit: November 29, 2006, 01:16:04 PM by heffay »
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #4 on: November 29, 2006, 12:01:45 PM »
Thanks, heffay, I wasn't thinking that you have to hold it in place, but that makes sense.  I think I may pick up one and play around with it.
'77 CB750k
Offline heffay
« Reply #5 on: November 29, 2006, 01:19:24 PM »
more of what i was meaning is if they actually seal off the intake ( like a compression tester )  the bike won't run very well on that cylinder due to lack of air... sparty, what did the magazine say?
Offline sparty
    • Gallery
« Reply #6 on: November 30, 2006, 05:11:09 AM »
The magazine article was in Bike.  A mechanic was tuning a sport bike with this gadget.  He said he always uses it and it works really well as it helps him dial in the individual carbs.
Sparty
Offline jabbadeznuts
« Reply #7 on: November 30, 2006, 12:54:12 PM »
Back in my Dad's college days, he had a 912 and used the "uni-syn" brand snail sync tool. He said it was the biggest pain in the a$$ to use ever.
'75 CB550
'82 Suzuki GN125 - glad to be rid of that thing.
Offline heffay
« Reply #8 on: November 30, 2006, 03:10:15 PM »
Sparty
so far you get a D+ on your book report...  ;)  can anyone verify whether or not the intake is cut off with this device?
Offline sparty
    • Gallery
« Reply #9 on: November 30, 2006, 05:51:05 PM »
Sparty
I didn't know I was being tested  :D  In that case, the air intake is not "cut-off" with this tool.  The tool has air ducts in the top/sides, which are not shown in the picture.  The pictures in the magazine are much better.  I'll re-read the article while I'm on the crapper. :P
Sparty
Offline sparty
    • Gallery
Re: The Snail Carb Synch Tool... new source and info.
« Reply #10 on: December 01, 2006, 04:52:16 AM »
Sparty
Here is some additional information on the flow meter. http://www.cbperformance.com/catalog.asp?ProductID=572
In the UK the flow meter sells for around 5 pounds.  In the US it is $40+   Ripoff.
Sparty
Offline heffay
« Reply #11 on: December 01, 2006, 10:36:14 AM »
thanks for the link spart... 40 bucks is dumb when i could buy something for a couple of bucks more that metered all the carbs at once.
my opinion of course.
eldar
« Reply #12 on: December 01, 2006, 10:47:01 AM »
I dont know hef. Look at it this way. You dont have to pull the tank off and hang it or a aux tank above you with a long hose that gets in the way. You meerly pull off the airbox or pods and go to town.  I am sure that it works fine and just require experience as does any carb sync tool.  I do agree that an article would be nice though.
Offline my78k
« Reply #13 on: December 01, 2006, 01:13:05 PM »
I dunno....after having to fight with my damn airbox to get it to go back on I think I would rather remove my tank and hang a reservoir.
Can't believe I just disgreed with the "Master"...I may have my K8 ownership revoked...  ;)
Dennis
eldar
« Reply #14 on: December 01, 2006, 01:24:03 PM »
You just dont talk to your airbox the right way!   ;D
Offline heffay
« Reply #15 on: December 01, 2006, 01:46:11 PM »
when i learned to take short intermissions during carb installs to break stuff... i became a much happier person
eldar
« Reply #16 on: December 01, 2006, 01:58:06 PM »
Ah PHOOEY! He is not equipped with the sword of a thousand truths! ;D
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #17 on: December 01, 2006, 02:11:58 PM »
I'm going to order one and file a report. :)
'77 CB750k
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #18 on: December 05, 2006, 09:20:17 PM »
Watch This Space ;)
Just ordered the snail.  Am now waiting will breath bated.  Will report soon.  Out.
'77 CB750k
« Reply #19 on: December 06, 2006, 03:40:14 AM »
You still have to remove the tank to adjust the carbs Eldy.....................  :-\ ;D
I've got some CR carbs for my racer project, but I'm going to turn up some alloy carb adapters to go betwixt carbs and head, with take offs for vac gauges. I've seen an article in a US mag where they used something like a big hypodermic needle pierced thru the rubber inlets as vacuum takeoffs, but I wouldn't recommend it. Cheers, Terry. ;D
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #20 on: December 06, 2006, 05:33:23 AM »
Removing the tank is OK for me.  I'm going to give it a go just to see if I can avoid tapping the intake adapters for vacuum fittings.  I'm using velocity stacks, so I figure it should fit.
'77 CB750k
eldar
« Reply #21 on: December 06, 2006, 06:27:09 AM »
Hmm must be another superiour design point of the K8. I would not have to remove the tank, maybe just lift it up some! :D
Offline Gordon
  • 750K1, 550K2
« Reply #22 on: December 06, 2006, 09:13:02 AM »
So you just hold up the rear of the tank with one hand and adjust the carbs with the other two?
Have you actually synchronized your carbs with the tank on the bike or is this just an hypothesis?
eldar
« Reply #23 on: December 06, 2006, 11:29:25 AM »
With current sync tools, you have to remove the tank to get at the vacuum ports. with this device, that is not needed. as such you should be able to lift the back of the tank with a strap a couple of inches and that is enough room to get to the adjusters.
« Reply #24 on: December 06, 2006, 10:55:35 PM »
Ha ha, you shoulda posted that in the BS post Eldy, on your poxy K8, you've gotta take the tops off the carbs to synch them, but I'm guessing you've never actually done that mate, or you'd know what you're talking about? ;D
