Author Topic: Cb350f fresh top end smoking like nuts!  (Read 15116 times)
Re: Cb350f fresh top end smoking like nuts!
« Reply #50 on: December 03, 2020, 08:10:28 AM »
Just joined this forum and have the exact same problem as jag767 had in 2016 with his 350F. Did anyone ever find the solution that could be shared here?
The CI rings are garbage.
I have similar stories about the CI rings (CBX kits).....poor tension
Offline markreimer
« Reply #51 on: December 03, 2020, 08:36:03 AM »
I contacted CI about this when it first happened to ask if they had any advice or similar experiences. They responded by blocking me on eBay.
« Reply #52 on: December 05, 2020, 02:15:30 PM »
Seems to be their standard operating procedure.
Offline SquierA
« Reply #53 on: March 24, 2021, 08:42:48 AM »
Ok update here. I took the valve cover off last night and all 8 valves do have valve stem seals installed on them. SO much for remembering the machine shop calling and stating that head doesn't use valve stem seals. So now it's a full top end tear down to install the 4 sets of Honda piston rings I've purchased. I sure hope this solves the problem because I'm out of ideas after this. I will update everyone once I get this completed. In the meantime if anyone has had this same issue and found a different solution please chime in.
Offline markreimer
« Reply #54 on: March 24, 2021, 08:57:25 AM »
Man, that sucks. I feel your pain... I never solved my 350f oil burning problem. Ended up selling it as-is. I tried OEM rings on the stock pistons the first time I rebuilt the engine but it still burned oil. Not as bad as the CI big bore kit, but still too much. Maybe OEM rings on an over-bore would have been the ticket.
There is such a disproportional number of oil-burning cb350f rebuild failure threads here. it seems to me that if I ever had a 350F again, and it started burning oil, I'd fix it by looking for a complete 400F engine to drop in.
Good luck and be sure to report back!
Offline SquierA
« Reply #55 on: March 26, 2021, 08:58:32 AM »
Quick update - Got the head off and there is about a teaspoon of oil on top of each piston. Talked to the machine shop and he agrees it sounds like the piston rings aren't sealing and am going to take the CI pistons to him with the Honda OE rings to make sure they will fit the pistons properly. Also gonna put a fresh crosshatch on the cylinders to help the new rings bed in. Fingers and toes crossed that this solves the problem.
Offline markreimer
« Reply #56 on: March 26, 2021, 09:35:04 AM »
That's wild, exactly the same result as I had with my Cruzin Image rings. A fresh hone and some quality rings should do it...
Offline chrisbc55
« Reply #57 on: March 26, 2021, 01:52:48 PM »
Shiny side up bro, in all things motorcycle  (including these rings- hard chrome edge faces the fire and is top ring).
« Reply #58 on: March 26, 2021, 06:56:37 PM »
While it is apart...measure the ACTUAL piston-bore clearance. You can do this by sliding a feeler gage alongside the piston skirt (front or back, not sides) and slide the piston into the bore (sans rings helps). It must not be more than 0.0008" on the 350F bore. I usually set those at 0.0004" (no, that is not a typo...).
Offline Trevor from Warragul
« Reply #59 on: March 26, 2021, 07:22:54 PM »
A fresh crosshatch could possibly make the piston to bore clearance too great. Listen to HondaMan, the clearance is critical on these tiny cylinders!
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Online grcamna2
« Reply #60 on: March 26, 2021, 08:00:21 PM »
++1  Make sure they're all 100% round,rather than oval-shaped.
Offline markreimer
« Reply #61 on: March 27, 2021, 09:58:13 AM »
I had mine done at .0004” and had the same issues. Rebuilt it again and had a second machine shop verify the piston to bore clearances as well as check for cylinder hour-glassing. It was all in spec. The cruzin image rings are garbage!
Offline Erwin83
« Reply #62 on: March 30, 2021, 03:46:49 AM »
Just throwing my experience in here:
I also had a smoking engine (400f) after rebuilding the top-end, using a Forseti kit from Australia (should be same or similar to CI). Also oil on the pistons (2-3) and subsequently in the exhaust which takes a lot of time to burn off.
Turned out to be the head-gasket. Apparently, the headgasket with this kit shrunk quite a lot.
Replaced the head gasket, torqued it, left sitting 24 hrs. Torqued again. Rode the bike gently for a couple dozen kilometers, and retorqued again. Seems OK now but I don't ride the bike that often.
CB466f
Offline caluser2000
« Reply #63 on: March 30, 2021, 02:24:39 PM »
Did you fit the four large skinny O'rings between the crank case and barrels? A randdom question I know.
Only thing I can think of is the rings gaps aren't set 120 degrees apart.
« Last Edit: March 30, 2021, 02:53:28 PM by caluser2000 »
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
« Reply #64 on: March 30, 2021, 03:58:52 PM »
Wouldnt cause that with the 3 piece oil rings
Offline caluser2000
« Reply #65 on: April 02, 2021, 02:45:33 AM »
I the gaps on those three rings are aligned together?
« Reply #66 on: April 09, 2021, 09:38:13 PM »
Here is an off-the-wall question, it might seem:
what torque wrench are you using for the head nuts?
Reason I ask: I had access to a brand-new set of 'click' torque wrenches a few years ago (2010, I think it was). Nice ones, it seemed, with calibration certificates in their boxes. Like all things lately, they were from China (I thought they were Harbor Freight, turns out not). I torqued a 750 head down with them to the 210 in-lbs I normally use. During the engine startup, about 5 minutes into it the shop filled with smoke(!). After cooldown (next day) I checked them again, retorqued with the 1/2 turn off, then back to torque, started up again, and...the shop filled with smoke! Third day, I brought in my trusty old beam torque wrench (300 in-lb max), now 50 years old. Torqued it to 210 in-lbs, but this took more than a WHOLE TURN MORE on every nut to reach that torque. Started up, ran for 20 minutes, no smoke.
I don't use click wrenches anymore.
Offline markreimer
« Reply #67 on: April 09, 2021, 10:15:47 PM »
Interesting idea there. Still, the fact that there are now maybe ten threads on SOHC4 with 350F smokey rebuilds, all using Cruzin Image kits, my bet is still that the common denominator is the culprit.
I’m not sure I’ve read any rebuilds where OEM oversize kits were used. Probably because they’re impossible to find. But it would be interesting to compare success rates. I think everyone knows how tight these little fours need to be, but still, it’s getting crazy how many guys are ending up with bad engines now.
« Reply #68 on: April 09, 2021, 10:42:17 PM »
I rebuilt my 350F using OEM Honda pistons & rings (2nd oversize).  Smoked like crazy & fouled the plugs, especially on cylinder number 2.  It was a piston to bore clearance problem.  In the end I bought a used standard size cylinder block with matching used pistons.  From memory, I sourced a set of standard OEM Honda rings, then went old school and cleaned up the bores with fine wet & dry sandpaper.  No smoking & dry plugs ever since...
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
« Reply #69 on: April 10, 2021, 09:47:52 PM »
This seems like a strange one to me. I've rebuilt 2 CB350F and 3 CB400F engines all with 0.5mm oversize CI piston sets. Not a lick of trouble with any of them. I also did a member's cylinders for a big-bore (393? CC kit) from CI, and that went fine, too.
Online grcamna2
« Reply #70 on: April 10, 2021, 10:28:42 PM »
« Reply #71 on: April 11, 2021, 05:35:51 AM »
Do you use a lathe to bore out the sleeves?  Seems to me this would be the way to most accurately do it...
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
« Reply #72 on: April 11, 2021, 07:39:26 AM »
A decent boring bar (van norman is one) will bore to 1 thou
Offline SquierA
« Reply #73 on: October 17, 2021, 09:08:48 AM »
Quick update everyone. I installed the Honda NOS rings on the CI pistons, had the machine shop measure piston to to bore clearance and set a fresh hone. Got the bike back together, fired right up ran great and didn't smoke until it got to operating temperature and it started smoking again. I rode the bike for 10 miles varying throttle and engine loads and the smoke continued. It's not smoking as heavily as it did before but I think that's b/c we put 100 miles on the previous build and the head pipe and muffler had filled with oil that I cleaned out during the second tear down. Another odd item is the bike's valve cover/crankcase vent tube is pouring out smoke, almost more than what's coming out of the exhaust pipe. I will pull the plugs today to confirm all 4 are oil fouled then I think it's time for a leak down test to see if the issue is in the head.
The machine shop looked at the CI rings and they appeared to have a nice seal wear on them. We also installed another new set of valve stem seals just in case that was the issue. The bike has plenty of power (as it did on the previous build) so I'm thinking it's in the head. Also the bike runs great and doesn't smoke when it's cold. Once it heats up it smokes, won't idle and has heavy hesitation throttling up but has plenty of power. I think the poor idle and hesitation is from the the motor oil fouling the plugs at low rpms.
Just throwing out all that I can to this group to assist anyone with this same issue. This is crazy that we can't figure out the issue. I will keep posting updates as they happen.
« Reply #74 on: October 25, 2021, 07:20:40 PM »
Bryan:
Have you used the Van Norman bar yourself? I am toying with the idea of getting one.
