Author Topic: Hot Street Motor on a Budget  (Read 23864 times)
Offline stikman
  • Bit of an
Re: Hot Street Motor on a Budget
« Reply #50 on: November 26, 2016, 03:53:48 PM »
I know it's not that exciting.  Certainly not as much as Bill's recent engine trouble.
Here's a shot of the worst valves, all exhaust.  Probably not worth reusing?
The valves have "CR" on the stems and say "Made in Japan" and IN or EX in raised letters on top.  Are these just stock valves?
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline dragracer
  • CB750F Dragbike
« Reply #51 on: November 26, 2016, 03:57:55 PM »
I'll be swapping the F2 cam for a CX-1 (Webcam 41) in my Street E/T dragbike posted earlier and will be able to post results. Current best ET is 13.38 at 97mph. I'll try to do the comparison before any sprocket changes. I'll be switching sprockets to try and get 5th gear on top end since I'm currently hitting my shift point in fourth gear right at the stripe.
That will be very interesting for sure.  If you end up with the 60ft number comparison too, that would be awesome.  When are you planning to test your changes?
Hopefully before the end of the year. We just finished the season in Valdosta over the weekend, so it's time for wrenchin'! Current 60' numbers are right at two seconds.
Get busy bud. We've got a bracket race in Bradenton on December 9. Paying good money too. Even if you don't race, it'll be a perfect time to test at a nice track. All bike event by the way. Get that cam in there and bring the sprocket and extra chain- you'll loose wheelbase otherwise. Lets do it!!! Gladys said she's entering the ET class. What's your excuse??? 😁
Offline BPellerine
« Reply #52 on: November 26, 2016, 04:34:00 PM »
I have never seen that type of valve,with markings on them,kinda cool.bill
1978 CB 750K ard and webers
another anfob
« Reply #53 on: November 26, 2016, 04:56:28 PM »
Norris used to mark their cams on a flat spot..got a cam pic... Plus they were a grey color.
The big valve clearance sure hints at a cam..Did it have decent power ?
Offline TurboD
« Reply #54 on: November 26, 2016, 05:24:17 PM »
Or bend valves. hehe
Offline BPellerine
« Reply #55 on: November 26, 2016, 05:29:12 PM »
I guess to answer your q they are not stock.bill
another anfob
Offline TurboD
« Reply #56 on: November 26, 2016, 05:31:50 PM »
Stikman What do the heads of the valves look like?
Offline stikman
  • Bit of an
« Reply #57 on: November 26, 2016, 06:32:14 PM »
Interesting.  I expect the excessive valve lash is more due to lack of maintenance.  The PO was that type to an extreme.  But now you've got me thinking and I'll have to do some measurements on the cam lobes.  The lobes are pretty worn, and the hardened surface of the rockers equally so.  I only ever started this motor once and it smoked like a pig.  Can't speak to how it felt.  But given the ring gap placements I can't imagine the compression was very good.  Ports haven't been touched before.
I was, however surprised to see 140 main jets in the carbs.
Valves look straight to me.  Anything specific to look for on the heads?  Nobody seen those CR valve markings before?
Offline TurboD
« Reply #58 on: November 26, 2016, 06:42:41 PM »
I was curious as to the shape of the valve head.
Offline stikman
  • Bit of an
« Reply #59 on: November 26, 2016, 06:49:03 PM »
Valve heads look fine, albeit coated in carbon.  But they don't look to have been hitting the pistons.  The pistons measure about 2.4", so 61mm stock size.  Intake valve head measures 32mm, and exhaust 28mm.
Here's a shot of the cam marking, "K8".
Lobes are pretty worn with some pitting.  I'll get some lobe measurements shortly.
Offline TurboD
« Reply #60 on: November 26, 2016, 06:52:02 PM »
Do the valves have the stock shape or flat like aftermarket?
Offline stikman
  • Bit of an
« Reply #61 on: November 26, 2016, 07:04:16 PM »
They are dished in the center like stock valves.  Just the raised lettering in that dish that I've not seen before.  You can see that in the pic I posted earlier.
Offline TurboD
« Reply #62 on: November 26, 2016, 07:31:11 PM »
The head side, where the shape is. I can see the flats. Lol
Offline stikman
  • Bit of an
« Reply #63 on: November 26, 2016, 07:53:01 PM »
Got it  :P.  They have the same ski slope lip around the edge as stock valves.
From what I can tell, the cam lobes measure similar lift to a stock cam, if not a hair shorter from wear.  I compared with a good K1 cam I have.
Base lobe:  1.110"
Intake lobe:  1.396"  (1.405" at the less worn outer edge)
Exhaust lobe: 1.386"
This cam left, K1 cam right
« Reply #64 on: November 26, 2016, 08:24:32 PM »
Sound like around  .375 lift..more than stock. To my eye it looks like a bit more duration.
The cam looks sorta grey in the R8 pic....does it look different in color than the K1 cam ?
Offline TurboD
« Reply #65 on: November 26, 2016, 08:28:56 PM »
1.396 - 1.110 = .286
« Reply #66 on: November 26, 2016, 08:53:58 PM »
My math sucks today..
Offline stikman
  • Bit of an
« Reply #67 on: November 26, 2016, 09:06:17 PM »
IN 1.396 - 1.110 = 0.286
0.286 x 1.1 rocker ratio = .315 valve lift
EX 1.386 - 1.110 = 0.276
0.276 x 1.1 rocker ratio = .304 valve lift
And color looks the same to me.  The cam has the normal R#, on this one it's R13, but the K8 stamping on the flat spot is extra.  It's weird and all, but the cam still looks to be stock to me.
« Reply #68 on: November 27, 2016, 06:48:38 AM »
I have a set of CR rods here....they are POS parts.
Offline stikman
  • Bit of an
« Reply #69 on: November 28, 2016, 10:14:40 AM »
Hmm okay, good to know.  Probably just cheap stock-type replacement parts eh.  Well I'm planning to replace the valves anyway, seeing as the rockers hammered a few of them and the raised letters can't be good for flow.  Do you think oversize intakes would be overkill with a wiseco 836 and webcam 41?  (I'll be deshrouding them anyway)
Also considering removing the valve guides to be able to grind out that cast lump around them.  Is this okay to do on a street motor and what guide material would be recommended?
« Reply #70 on: December 01, 2016, 04:52:52 PM »
That is a great idea...have the seats ID's bored to .9 and blend into the port. Here is what I would do. Leave the old guides in and bore the seats. Remove the guides and work on the guide boss and seat area. use the Kibblewhite iron guides. If you have a lathe taper the guides. You will need to have the guides honed and a valve job
Offline stikman
  • Bit of an
« Reply #71 on: December 01, 2016, 07:06:55 PM »
Okay, perfect!  I was hoping you'd chime in on that, Mike.  So would you recommend doing this for both intake and exhaust;  guide taper and boss removal?  I've got it in my head for some reason that removing the EX valve guide boss would expose the guide and make it prone to getting too hot.
Also, any recommendation for running without valve seals on the street, like the earlier models?
Final question for the day, what would be the recommended piston to wall clearance for NOS forged Wiseco 836cc pistons (4016PS - no micro grooves) in stock sleeves for my application?  Is less than .0020 getting too tight or is it reasonable as long as you take your time breaking it in?
« Last Edit: December 01, 2016, 07:47:09 PM by stikman »
« Reply #72 on: December 02, 2016, 06:43:49 AM »
 You can remove or taper the intake boss. I taper the exhaust boss after the guide.....the exhaust flow really well without much work. Bead blast the ports before removing the guides.
 Valve guide seals are a must
 I'd run those old Wiseco's at .002
Offline stikman
  • Bit of an
« Reply #73 on: December 02, 2016, 06:46:28 PM »
Sounds good.  Thanks alot for that, Mike.
Offline stikman
  • Bit of an
« Reply #74 on: December 03, 2016, 07:18:28 PM »
Couple more questions.  Is there a good place to get those CBX exhaust studs to replace the four 6mm head bolts?  And do you install the studs with anything, like locktite?
Any recommendations on what would be a reasonable amount to advance the webcam 41 to move the powerband down lower (going in a chopper)?  I'm considering drilling a stock cam sprocket to get between 5 and 10 degrees advance.
I assume I should be fine using the Kibblewhite chromed stem SS valves in the cast iron Kibblewhite guides.
