I rebuilt the carbs on my '75 550 with new K&L kits - these were the gunkiest carbs I've ever tried to clean and although they turned out well, I figured it might take a couple of tries to get them right. It starts well (once I figured out the procedure) and I got in a few short rides before it started missing (fully warmed up) at low speed. By that I mean about 1/4 throttle - crank it open past about 1/2 and it smooths out and pulls well. I have a perfect rust free tank with a new filter on the petcock. I'm thinking blocked pilot/low speed crap aftermarket jets? And can I get the jets out without removing the carbs? Thanks
Replace these suspect parts with new OEM Keihin Jets, and only then, complete a clear tube test of your carb bowls (dont trust aftermarket float valve heights) to ensure accurate fuel levels, and then proceed with an idle plug chop on new plugs to dial in your IMS.
