Author Topic: CB550 carb question  (Read 1542 times)
Offline calal
CB550 carb question
« on: November 14, 2016, 01:42:19 PM »
I rebuilt the carbs on my '75 550 with new K&L kits - these were the gunkiest carbs I've ever tried to clean and although they turned out well, I figured it might take a couple of tries to get them right.  It starts well (once I figured out the procedure) and I got in a few short rides before it started missing (fully warmed up) at low speed.  By that I mean about 1/4 throttle - crank it open past about 1/2 and it smooths out and pulls well.  I have a perfect rust free tank with a new filter on the petcock.  I'm thinking blocked pilot/low speed jet?  And can I get the jets out without removing the carbs?
Thanks
Offline Gene
  • Chat enuf you too can be a
Re: CB550 carb question
« Reply #1 on: November 14, 2016, 01:49:44 PM »
You can drop the bowls with the carbs on.  You'll need a screwdriver that will fit unless you replaced the bowl screws with allen heads (if you haven't, you should) :)
*1973 CB750K3 (Bow)
« Reply #2 on: November 14, 2016, 01:59:39 PM »
I rebuilt the carbs on my '75 550 with new K&L kits - these were the gunkiest carbs I've ever tried to clean and although they turned out well, I figured it might take a couple of tries to get them right.  It starts well (once I figured out the procedure) and I got in a few short rides before it started missing (fully warmed up) at low speed.  By that I mean about 1/4 throttle - crank it open past about 1/2 and it smooths out and pulls well.  I have a perfect rust free tank with a new filter on the petcock.  I'm thinking blocked pilot/low speed crap aftermarket jets?  And can I get the jets out without removing the carbs?
Thanks
Replace these suspect parts with new OEM Keihin Jets, and only then, complete a clear tube test of your carb bowls (dont trust aftermarket float valve heights) to ensure accurate fuel levels, and then proceed with an idle plug chop on new plugs to dial in your IMS.
Online BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: November 14, 2016, 02:03:15 PM »
Have you tested your ignition condensers?
Missing at low rpm and running strong up high is a sign of that.
Offline Gene
« Reply #4 on: November 14, 2016, 03:47:36 PM »
And this.  Don't scrimp on carb parts.  That's what makes the bike go.
*1973 CB750K3 (Bow)
Offline b52bombardier1
« Reply #5 on: November 14, 2016, 03:55:41 PM »
I just removed all of the aftermarket brass and the float valves from my CB500 carbs because they were junk - sooty spark plugs and leaky overflows.
Replaced it all with better OEM Honda Keihin items and the bike runs vastly better. Yes, this stuff was expensive but the bike was a rolling Molotov Cocktail with a bad miss with the aftermarket items.
All good now.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline calal
« Reply #6 on: November 14, 2016, 05:07:11 PM »
Thanks everyone for the suggestions.  I'll look for dirt in the jets first, and proceed from there.  I forgot to mention that the choke lever will mostly cancel the miss, so it's probably not electrical.
Offline calal
« Reply #7 on: November 14, 2016, 11:46:49 PM »
I've had good luck with the K&L kits in the past for both carb and petcock rebuilds, but in this case I reused the stock needles to eliminate the variable.
