Author Topic: Hoop installed - enough surface to support seat?  (Read 1992 times)
Offline Sox Fan
« on: November 24, 2016, 10:05:07 AM »
Starting to make some progress with my build. Cut the rear frame and welded in a hoop and a couple of braces for a flat, brat style seat from Dime City. I think this is enough surface to mount the seat?
Re: Hoop installed - enough surface to support seat?
« Reply #1 on: November 24, 2016, 10:14:00 AM »
and the back wheel goes where when the suspension compresses?
Offline firebane
« Reply #2 on: November 24, 2016, 11:10:41 AM »
Quit being so silly shocks don't compress.
« Reply #3 on: November 24, 2016, 11:33:23 AM »
thats what I thought until one day when I stopped looking at trendy bikes online and actually rode one
« Reply #4 on: November 24, 2016, 12:00:11 PM »
Just weld up a hard tail  and let your spine handle the compression.  It is all for the looks anyway...cafe bikes and brats to be ridable jewelry for many. They won't ride them in the rain or when it drops below 55-60F.
Shocks, who needs shocks?
Offline Sox Fan
« Reply #5 on: November 24, 2016, 12:10:54 PM »
Sorry - what does that have to do with mounting a seat?
« Reply #6 on: November 24, 2016, 01:13:02 PM »
He was trying to point out that flattening the rear with a hoop that is flat will not provide the tire clearance when the rear suspension fully compresses. This results in very bad things happening when that occurs.
« Reply #7 on: November 24, 2016, 02:44:27 PM »
dude, your seat will be mounted strong...don't worry about the back wheel hitting
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #8 on: November 25, 2016, 03:38:49 PM »
Nice job welding in the hoop.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline Sox Fan
« Reply #9 on: November 26, 2016, 08:27:44 AM »
Thank you. Rookie welder.
Offline Sox Fan
« Reply #10 on: November 26, 2016, 08:32:32 AM »
Its more than enough surface area and bracing to support your seat. In fact, with a closed loop, the cross bracing is superfluous. To Sean's point, you may actually want to remove the flat stock to allow the tire to move upwards during suspension compression so as not to conflict with the brace/tread.
Thanks for your thoughts. Very helpful.  That brace all the way back I don't think will be any lower than the underneath of the seat so I suppose if it is going to rub, the rear tire will either hit that brace or the bottom of the seat.  Will have to see what shock setting is best once I have the rear wheel installed.
Offline Steve_K
« Reply #11 on: November 26, 2016, 10:16:57 AM »
It is easy to check clearance.  Remove one shock, take spring off(I can do with my hands) and put back on.  Remove the other shock and raise the wheel and check with shock compressed.  Easy to with a centerstand, but do able without.
Steve
Steve_K
