Author Topic: 550 cam chain prob.  (Read 7129 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 550 cam chain prob.
« Reply #25 on: December 18, 2016, 11:38:09 AM »
Bomber, have to make enough for you too...
you are risking the naughty list calling Santa such words, do you kiss your mother with that mouth?  ;D ;)
I wouldn't mind being on the naughty list if it meant being with the gals on BobbyR's thread  ;D
Offline Killer Canary
  • Typical Bran Muffin
« Reply #26 on: January 05, 2017, 05:25:21 PM »
This might sound like a stupid question but I must: do all year of Honda 550 fours use the same length cam chain?
Kawi GPz900, H1
« Reply #27 on: January 05, 2017, 06:45:15 PM »
The chain they sent me is too facking short.
Kawi GPz900, H1
« Reply #28 on: January 05, 2017, 07:41:21 PM »
Understood.
As an experiment, I fit the sprocket to the chain without the cam (or tensioner!) installed and the sprocket opening is visually well below the journals.
The chain will have to do a lot of stretching to fit.
Pictures tomorrow.
Kawi GPz900, H1
« Reply #29 on: January 05, 2017, 10:10:33 PM »
Where did you buy your chain?
« Reply #30 on: January 06, 2017, 05:32:19 AM »
I don't remember. I've been gathering parts together for a few years now.
It was a cheapo though.
I should have re-used the old chain; it used to install with no fuss.
Kawi GPz900, H1
« Reply #31 on: January 06, 2017, 10:07:04 AM »
Not a hope in heck.
Kawi GPz900, H1
« Reply #32 on: January 06, 2017, 11:26:43 AM »
Already did that.
It was a fight to get the chain onto the sprocket, excessive force might get the sprocket onto the cam.
If all is well, no force is required.
You mentioned that earlier and that's been my experience with previous rebuilds.
Are you saying that installing a new chain does require force, and is no longer a slip fit?
How much force have you needed to use when installing a new chain?
Did the journals stand up to the pressure?
« Last Edit: January 06, 2017, 11:32:07 AM by Killer Canary »
Kawi GPz900, H1
« Reply #33 on: January 06, 2017, 12:37:12 PM »
I appreciate your clarity Cal. :)
I had the cases split to replace the primary chain, add 650 tensioner, clean/paint,
etc so I replaced the cam chain while I was at it.
None of this was supposed to happen!
I replaced seals in the head several years ago, re-installing the old chain and everything slipped together like it was supposed to.
I sure didn't foresee anything like this.
I'll have to go with a rivet chain, which was what I didn't want in the first place, so that I won't have to split the cases again.
Kawi GPz900, H1
« Reply #34 on: January 07, 2017, 05:32:15 AM »
I fixed the cases for a 650 primary tensioner.
Cam chain tensioner remains stock 550.
Kawi GPz900, H1
  • Holy Cow! I'm a
« Reply #35 on: January 07, 2017, 07:49:32 AM »
I was really considering the primary tensioner mod too.  Was it simple enough to accomplish?
« Reply #36 on: January 07, 2017, 07:59:41 AM »
Basic measuring and fabbing skills.
I used a milling machine because I have access to one, not a necessity though.
I welded a foot long extension to a drill bit to facilitate clearing the case when drilling the external mounting holes.
That's about it.
I also machined an aluminum extension for the oil pump pickup so that I could retain the stock 550 item.
I was going great guns until this chain horses**t stopped me dead in my tracks. >:(
« Last Edit: January 07, 2017, 08:02:45 AM by Killer Canary »
Kawi GPz900, H1
« Reply #37 on: January 21, 2017, 02:59:54 PM »
Don't be a jackass like yours truly.
Install the chain guide facing forward and not backward. ::)
Kawi GPz900, H1
