SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
What speedo is this?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: What speedo is this? (Read 1486 times)
elcid
Guest
on:
December 06, 2006, 12:55:28 PM »
The Yamaha speedo in upper left - what model/ year is it from? I want to use it on my build.
[/img]
Logged
grumburg
Expert
74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Re: What speedo is this?
Reply #1 on:
December 06, 2006, 12:56:59 PM »
Looks like a 66-68 305.
Logged
Fonda Honda
elcid
Guest
Reply #2 on:
December 06, 2006, 01:00:44 PM »
damn I want it! You know of any other make/ model/ years that made an integrated speedo & tach unit?
Logged
Bob Wessner
"Carbs Suck!"
Really Old Timer ...
Reply #3 on:
December 06, 2006, 01:08:10 PM »
Wouldn't you have to determine if the ratios were correct?
Logged
mrbreeze
Not your average
Shut up when you're talkin' to me!!
Reply #4 on:
December 06, 2006, 01:12:41 PM »
I don't know what its from but like Bob says....you would want to make sure its the right ratio. If you like to go for the ton,you will be maxing this one out.
Logged
MEMBER # 257
SD750F
Master
Reply #5 on:
December 06, 2006, 01:13:16 PM »
You would only have to worry about the ratios if there was only one cable. I doubt there is only one cable. You would have to have a gear sensor as well as a speed sensor... I bet there are two separate gauges in one housing.
Scott
Logged
Geeto67
A grumpy
Old Timer
Reply #6 on:
December 06, 2006, 02:17:52 PM »
Looks like a 1967 YR1 speedo/tach to me. I had a friend who used on on his rd350 and said it read accuratly (he checked the tach with a dwell meeter). Speedos tend to be pretty standard but the tach is probably no good for your bike since it came off a two stroke bike.
Why not use the 60's cb77, cb450 headlight speedo (at least with them you can use the guts of a minigauge to get the tach to read somewhat accurately). same effect just an oval instead of round.
Logged
Maintenance Matters Most
csendker
Master
Chris; '75 CB550 & a Crusty 'ol boat
Reply #7 on:
December 06, 2006, 04:59:51 PM »
Look back to the Black Bomber...
Logged
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery -->
http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
mrbreeze
Not your average
Reply #8 on:
December 06, 2006, 05:28:12 PM »
That one has a bit more room to ton.I'll bet it ain't very easy to get one though.
Logged
MEMBER # 257
csendker
Master
Reply #9 on:
December 06, 2006, 05:37:19 PM »
Anything from a Bomber is gonna be tough to get without losing a lot of coin (insert: "Sandcast"). But, there's several Honda's with the integrated headligt/gauge thing, like the '69 CA175. I bet it's a lot cheaper the the Bomber unit.
Logged
Gallery -->
mlinder
"Kitten Puncher"
Stop Global Tilting now!
Reply #10 on:
December 06, 2006, 05:50:51 PM »
BMW /5's did.
Logged
No.
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
