Author Topic: Sure would be nice if they published the specs on these exhausts  (Read 985 times)
Offline eigenvector
« on: February 13, 2017, 04:36:34 PM »
I picked up a set of repro 4 in 4 exhausts for my CB550.  Since I don't have the stays I have to manufacture them.  I have the stays made, but whoever made the exhaust didn't include nuts for the bolts that are embedded in the muffler.
I guessed based on my micrometer - figuring it was a standard 8mm.  NOPE!  So now I have to run to the hardware store to pick up a selection of nuts to see which one it is.
8mm fine pitch?
5/16"?
5/16 fine pitch?
It is for a Japanese bike, so I am making a big assumption that it's metric, but 8mm 1.25 pitch (standard) was close but no cigar.
The other wrinkle - the upper pipe uses a 10mm bolt, but they included the nut for that ???
Why use 2 fine pitch 8mm bolts on the lower pipe and a single 10mm standard pitch bolt on the upper.  Beats me.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Sure would be nice if they published the specs on these exhausts
« Reply #1 on: February 13, 2017, 07:30:47 PM »
You have a mcrometer but cant measure pitch? Just use a caliper or ruler and count.
Mm is .040 for this exercise..
1.5 mm pitch is very near to 16 tpi... Or use loose bolts you have to compare pitch.
« Last Edit: February 13, 2017, 07:32:30 PM by 754 »
Offline bender01
« Reply #2 on: February 13, 2017, 07:53:49 PM »
Where did you find these repros? Are they for pre 77 K or later?
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline eigenvector
« Reply #3 on: February 15, 2017, 05:34:34 PM »
I really just wanted to gripe.
For as much as they sold the kit for, you think they could have thrown in 2 bucks worth of hardware.
But I will say this - it ain't 8mm 1.25 or 1.0 pitch.  it's not 5/16 x18 or 24 either.
My solution - they chrome the plated the bolts with messed up the threads, I'm going to recut them with an 8mm x 1.25 pitch die and be done with it.
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #4 on: February 16, 2017, 07:09:38 AM »
M6.  Either 1.0 or 1.25
Offline eigenvector
« Reply #5 on: February 16, 2017, 07:48:43 PM »
Nope.  Definitely 8mm x 1.25 pitch.
I recut the threads and they were all junked up with chrome plating.
Looks like I'm going to have a busy weekend putting the new pipes on.
Rob
1977 CB550K
1983 VF750S Sabre
