Author Topic: Reinstalling fork caps and keeping the skin on your hand.......  (Read 11232 times)
misterskin
« on: December 09, 2006, 04:58:03 AM »
A tip to getting the fork caps back on while under presure (if you are adding the PVC spacer described a couple of threads down)......  Go buy a CHEAP rubber mallet.  Take the mallet head off and throw the handle away.  Take a razor/exacto blade and cut an outline of the "nut" on the fork cap into one end of the mallet head, basically making a big a$$ rubber socket.  You can use this to push & twist that cap back down and get the threads started easier, saving the palm of your hand!
I have done the spacer thing on dang near every bike I have had.  From one inch spacers in stock length forks, to making up the differences in 8/10 inch over forks on choppers.  Sometimes these can be a booger to get started and pressing on a big piece of rubber is much more comfortable, and easier than pressing on a socket/rachet combo and trying to turn it at the same time!
Offline jaknight
  • ....Round Town Ride......
Re: Reinstalling fork caps and keeping the skin on your hand.......
« Reply #1 on: December 09, 2006, 07:58:42 PM »
     Good idea........... will give it a try next time I pop those caps to change/add oil.
     Love that 750 avatar you've got 8) 8)
     ~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline kghost
« Reply #2 on: December 09, 2006, 09:48:18 PM »
hmmmm......
I just use the wooden handle to press down on the cap while gripping the rubber head.
Then I spin the nut with the wrench from the tool kit......
Stranger in a strange land
Offline turboguzzi
« Reply #3 on: December 12, 2006, 01:34:27 PM »
Destroying  a hammer and on top of that having to cut it?
I just use a socket (size of the hex on the cap) + an extension as a handle. gives you a good sense of the direction you are screwing so it's harder to cross thread.
You can take out a lot of your guess work by unscrewing slowly the cap (without the spring) and making a small mark of the postion where the last thread ends. Both on cap and triple clamp. When you screw in the cap, start your twisting just  a couple milimeters before your mark so that the thread catches immediately after 1/4 of a turn.
Works every time
skidpan
« Reply #4 on: December 12, 2006, 01:42:35 PM »
Thats a shockingly good idea, turboguzzi
misterskin
« Reply #5 on: December 12, 2006, 10:20:22 PM »
I got the hammer from "The Dollar Tree", one of those everything is a buck stores...it was 100 pennies.  Not like I wasted a 20 dollar hammer.   ;)
Offline Rsnip988
« Reply #6 on: December 23, 2006, 09:53:45 AM »
Works every time
worked for me
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline Mekagojira
« Reply #7 on: January 26, 2011, 12:44:19 AM »
Any other tips? I'm going to try the mallet thing tomorrow.  I am assuming  my springs are good since I can't get the caps in easily…?
Started my first fork oil change hours ago...
1975 CB750F
« Reply #8 on: January 26, 2011, 01:07:16 AM »
You do have the weight off the front end .? Make sure there is no weight on the front wheel and it is off the ground and i use a large good quality socket..
Offline Mekagojira
« Reply #9 on: January 26, 2011, 01:49:35 AM »
Thanks -
Yeah, bike on center stand, then I jacked it so the front wheel was an inch up…
These springs are like 4 inches out - it takes all I got to press them back in while holding the socket - I'm pressing so hard the wrench won't ratchet…  ???
1975 CB750F
Offline turboguzzi
« Reply #10 on: January 26, 2011, 04:34:21 AM »
dont use the ratchet, just a socket extension as a handle
and read my prior advice on starting the cap on the threads, it's all there .... ;)
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #11 on: August 17, 2011, 11:17:36 AM »
I just pushed down the nut with all I had and had the wife give it a couple spins with a open end wrench. No cussin and no fussin
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Spiider
  • '73 CB750k
« Reply #12 on: February 04, 2012, 02:46:49 PM »
I know this is late but a correct fitting socket and a speed handle work great too.
You can use both hands to press down with the speed handle and then turn it ccw to set up the threads a full turn then cw to start screwing it down.
It's never taken me much effort to get them to go back in properly first try.
Offline MoMo
  • Ride like you're invisible
« Reply #13 on: February 04, 2012, 03:26:28 PM »
Another late reply, but every mechanic I worked with for the 14 or so years I wrenched used this- a sliding t-handle with a ratcheting adapter and the proper socket. The T gives you pressure on both sides and the ratcheting adapter lets you to get the feel of when the cap is properly threaded...Larry
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #14 on: April 19, 2012, 10:43:19 AM »
^nice!
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
