SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Vacuum gauge intake bolts
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Vacuum gauge intake bolts (Read 647 times)
camshaft1991
Hot Shot
on:
February 20, 2017, 11:02:39 AM »
So, I've stripped the heads of to two sets m5x6 bolts on my cb350f. The bolts cover four holes in cylinder head block intake and are the insert points for my vacuum gauges. I've stripped the OEM screw heads and a socketed set. I got them out but they can't seal because of the stripped heads. Can I use anti-seize here and would using cupped washers offer any benefits like keeping it more air tight?
Logged
camshaft1991
Hot Shot
Re: Vacuum gauge intake bolts
Reply #1 on:
February 20, 2017, 11:27:52 AM »
I used a mini socket wrench but I guess I did go ape on them. Also would removing them after heating up the engine help too, or would a cold engine block be best?
Logged
whizzer
Full Member
Be safe
Reply #2 on:
February 20, 2017, 03:00:12 PM »
Motion pro sells set of permanent connectors. Small brass tubes, left in place, and covered with rubber caps. I installed them to end risk of stripping threads. Also easier to use than installing long tubes each sync.
Logged
72 cb350f
66 cb77 sold
72 Suzuki gt750 given away
59 Vespa given away
06 Whizzer sold
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
