Author Topic: Gauge lowering options?  (Read 2245 times)
Offline -JP-
« on: February 24, 2017, 06:30:40 AM »
Hello,
I would like to lower my gauges a bit, but I have this so called "unicorn" upper triple. I`ve searched the forum and found out that lowering is easy task if you have newer upper triple where the gauges mount differently ( http://forums.sohc4.net/index.php?topic=63166.0 ). I would like to use my old gauges if possible.
Is it possible to bend this unicorn part? I think it`s cast aluminum so my first toughts were it will crack. Secondly it`s quite expensive part so destroying it is not an option.
I also read that newer model triples won`t work because there is a different offset. Secondly newer gauges mount from beneath with bolts on a bracket. Mine just squeeze on a holder that is connected to the unicorn tip. So the easiest way would be to bend the part (risky). Second is to cut the part and weld it on a different angle. Third would be fabricating some kind of bracket.
Any other methods/ideas? Anyone done this?
-JP-
Offline 540nova
Re: Gauge lowering options?
« Reply #1 on: February 24, 2017, 07:06:44 AM »
Get an aftermarket triple from Cognito  Moto, and drill/tap 2 holes on the bottom for a gauge bracket.
Sell your old triple to an old asian dude. They believe unicorn horns have medicinal properties.
Offline slikwilli420
  • Master of Disaster
« Reply #2 on: February 24, 2017, 07:09:01 AM »
Definitely don't cut it or modify it. With the gauge rings it will probably pay for most of a new tree.
I make top trees as well and have a number of designs available. Any of which would work with your gauges. The link is in my signature if you are interested. Feel free to shoot me a PM as well.
« Reply #3 on: February 24, 2017, 08:13:06 AM »
Swap the top and bottom triple trees to a newer model, I'm sure someone will trade you for a later set and toss in a steel gauge bracket too.
Offline gschuld
« Reply #4 on: February 25, 2017, 01:48:42 PM »
I believe the 73-78 cb750K trees are 60mm offset just like the early unicorn trees.  The 76-78 F model trees are 50mm offset.
George
Offline -JP-
« Reply #5 on: March 03, 2017, 11:27:04 PM »
Yeah, like you all said better to leave it be and get a new triple or something. I would like to keep it looking vintage so I'm would prefer an old/oem triple. Also I would like to preserve that light unit on top of the triple. I think it's possible to mount it on any triple, but an oem would be the number 1 choise.
Offline -JP-
« Reply #6 on: March 03, 2017, 11:39:17 PM »
Can anyone confirm this? I need to be sure so I don`t order a wrong part.
If somebody has a spare 73-78 cb750k upper triple please feel free to contact me.
Offline -JP-
« Reply #7 on: March 04, 2017, 04:10:04 AM »
Ok. Thanks a lot.
« Reply #8 on: March 04, 2017, 06:10:06 AM »
I have a triple that I will trade you. I believe it has fresh black powder...
