Author Topic: Intalling killswitch control and throttle assembly question  (Read 583 times)
Offline Dos
  • Owner of a cb350f
« on: March 09, 2017, 04:54:43 PM »
Hey everyone,
I am installing club man handle bars and wiring from the outside.
I am in the process of drilling a small hole on the right side of the handle bars so the kill switch assembly can fit in properly ( any tips on how to make this easier?)
I disengaged the throttle cables when taking off the assembly but now that I am getting it back on, how do I re engage the throttle cables on the throttle sleeve and what position does the sleeve have to be in?
I am guessing that the hole needs to be drilled first then the assembly goes on then the sleeve in the assembly with the wires attached and then I can screw down?
I was also curious if anyone had a cable diagram for the cb350f. I am trying to be as neat as possible and keep the wiring in the same exact place specifically the clutch cable and the two throttle cables.  I believe the two throttle cables go to the left and go under the gas tank and rest on a little latch before being attached to the carbs?
Thank you I really appreciate it!
Offline Dos
  • Owner of a cb350f
Re: Intalling killswitch control and throttle assembly question
« Reply #1 on: March 10, 2017, 03:14:29 PM »
I guess it's pretty simple. I have stopped halfway due to the weather but will resume shortly just wanted to know
