Author Topic: CB500 Neutral Light Not Working  (Read 2354 times)
Offline cb
« on: April 07, 2017, 02:06:31 PM »
My CB500 K0 neutral light is not lighting up at all.  From browsing Ebay it sounds like this is a common problem for this model.
If so, is there a common solution I could try before doing the entire drill from checking the light bulb down?
BTW I would have searched the forum but the search function does not work for me.
Thank you in advance.
Re: CB500 Neutral Light Not Working
« Reply #1 on: April 07, 2017, 11:27:04 PM »
Not that I know.
'the entire drill'... are you serious? There's a lamp, there's a switch and there's a wire. How much work can that be? Have you done the easiest yet: to see if the little bulb is still good?
« Last Edit: April 08, 2017, 12:27:02 AM by Deltarider »
Offline cb
« Reply #2 on: April 08, 2017, 02:10:45 PM »
This is really helpful; thank you very much.  Now I have a path forward.
« Reply #3 on: April 16, 2017, 02:33:56 AM »
Have you found out what was wrong?
Offline cb
« Reply #4 on: April 20, 2017, 04:56:26 PM »
Yes, it was simple.  A wire had come off of its terminal.
« Reply #5 on: October 27, 2017, 07:08:02 AM »
it works!!!!!   Now I have 34 pages to read up on the BEST oil to use!!!
