Author Topic: Valve job  (Read 1759 times)
Offline Tack
Valve job
« on: April 11, 2017, 01:17:49 AM »
How do you determine the size of cutters required for valve seats ?
This is a general question for any head on any bike. Never done this before if the angles required are 30, 45 and 60 degrees what do you look for? I must change a inlet guide and light pitting on 2 exhaust valves , lapping will not remove the pitting. The bike in question that requires the work is a CB550k3 can anyone point me in the right direction, thanks in advance
Tack
Offline 700504
Re: Valve job
« Reply #1 on: April 11, 2017, 11:48:29 AM »
If I'm not mistaken, most high end valve cutters are angled to spec and then are adjustable for the size you need. The tools are spending though, don't get the ones made in India. Just make sure you get the correct size tool guide to go into your valve guide.
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
Offline Tack
Re: Valve job
« Reply #2 on: April 11, 2017, 12:38:33 PM »
In their lies the dilemma, spend a grand on correct cutters that may never be used again or chance the India ones, send it to a shop and learn nothing plus no local shop would be willing to do the job
Re: Valve job
« Reply #3 on: April 11, 2017, 12:57:18 PM »
Posting your location may help.
Offline 700504
Re: Valve job
« Reply #4 on: April 11, 2017, 12:58:20 PM »
From what I've heard, Neway is a good brand, look into them, should be under $500 for a set. Get yourself a cheap head, get good at cutting them and then do jobs yourself, make the tool pay for itself. Heck you can tear into old busted lawn mowers for good cheap practice.
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
Offline Tack
Re: Valve job
« Reply #5 on: April 11, 2017, 01:47:14 PM »
Neway will look out for them and location is County Cork,Ireland
Offline Bankerdanny
  • Endeavor to persevere
Re: Valve job
« Reply #6 on: April 11, 2017, 02:01:28 PM »
My brother-in-law lives in County Cork, out in the country, but relatively near to Cork City where he works for Apple.
Offline Tack
Re: Valve job
« Reply #7 on: April 11, 2017, 02:46:49 PM »
North, East or west doesn't matter all nice areas 8)
Offline Bankerdanny
Re: Valve job
« Reply #8 on: April 11, 2017, 03:26:16 PM »
I haven't visited him, but I've seen pictures of his house and the land and it is absolutely beautiful.
Offline Tack
Re: Valve job
« Reply #9 on: April 12, 2017, 01:45:23 PM »
If I'm not mistaken, re-cutting your seats requires honing/replacing your guides so the stem is perfectly centered afterwards.
Calj737 I bow to your superior knowledge on all two wheeled things and you have not steered me wrong BUT if the valve and guide are centered with the with the seat why would I replace the guide. Due to my lack of knowledge on the subject it dose not make sense
Tack
Offline Tack
Re: Valve job
« Reply #10 on: April 12, 2017, 01:53:55 PM »
If your interested I emailed Neway and this is what they sentand easy to contact
Offline Tack
Re: Valve job
« Reply #11 on: April 12, 2017, 02:11:27 PM »
Understand thanks
Offline 700504
Re: Valve job
« Reply #12 on: April 12, 2017, 02:40:26 PM »
Very cool, and to go off what cal was saying; If you're considering overhauling the head you'll replace the guides, hone them for new valves and recut the seats.
Here is a bit of good info from Hondaman and 70CB750 in this thread on replacing the valve guides: http://forums.sohc4.net/index.php?topic=127377.0
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
Offline Tack
Re: Valve job
« Reply #13 on: April 12, 2017, 03:06:04 PM »
Info is gold thanks for the link
Re: Valve job
« Reply #14 on: April 14, 2017, 10:57:29 PM »
 Can't you get the cutter heads with a different angle on each end? Mine's like that. 30 and 45 I think. You just need one of those and one regular.
Re: Valve job
« Reply #15 on: April 14, 2017, 10:59:29 PM »
 New guides means cut the valve seats, not vice versa. If a head had perfectly acceptable guides you could touch up the seats and leave them but most of the time one leads to the other.
Offline Tack
Re: Valve job
« Reply #16 on: April 16, 2017, 02:52:15 PM »
Thanks for "unconfusing" me, Don  :D
700504 ,Don & cal thanks for the info .
