Author Topic: Wheels  (Read 999 times)
Offline silver fox
Wheels
« on: December 15, 2006, 02:36:48 PM »
Does anyone know if a wm2(front) and wm3(rear) x19's will fit my 400/4, and are there any decent tyres available for this size???
Many thanks
Silver Fox
Offline cafe75-550
Re: Wheels
« Reply #1 on: December 15, 2006, 06:12:44 PM »
A WM2 front works out to be a 1.85 inch wide rim, a WM3 is a 2.15 inch wide rim. These are British designations and were probably intended for Triumphs, BSA's, Norton's, etc. The thing that might be different is the pitch of the holes, ie, spoke holes (and dimples) for drum hub rims have a different pitch than disk hub rims because of the difference in the hub diameters, so the spokes leave the rims with a steeper or shallower angle to match the hub. These are basically the same size rims as the 550's had originally, not sure about the 400, and there is a decent (but not huge) selection of tires that will fit.
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Offline Kevin400F
Re: Wheels
« Reply #2 on: December 15, 2006, 06:42:59 PM »
You might have some front fender clearance problems moving up from the 18" original diameter to the 19" rim.  Widths are fine.  There are various 90/90-19 front tires available, but a 19" rear is much less common.  Avon makes a few.
