SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Good spark but wont start
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Good spark but wont start (Read 1219 times)
DaSchwartz
Full Member
No matter where you go, There you are...
on:
May 30, 2017, 03:30:51 PM »
Sup folks! my girl sparking good again. Yay! now she just turns over and over and backfires after after a few cranks. Won't start.... and yes i have fuel and the kill switch is on run.... any suggestions? Thanks! Ken
Logged
Jimray23
Hot Shot
Re: Good spark but wont start
Reply #1 on:
May 30, 2017, 03:38:19 PM »
Well it takes 3 things for a gas motor to run.
1. The correct air/fuel ratio
2. Compression
3. Correct timing
I would check compression and timing to make sure those are good. If those are good its got to be fuel.
Jim
1979 kz1000b ltd
stage 3 cams
pod air filters
4-1 open exhaust(no muffler)
full rewire
dyna-s ignition
dyna 3 ohm coils
Logged
atm cycles
Hot Shot
Reply #2 on:
May 30, 2017, 03:38:34 PM »
Coils wired correctly. Timing? If you have spark, fuel and compression it much else but spark not at the right time
Logged
Ridem32
Hot Shot
Reply #3 on:
May 30, 2017, 03:39:07 PM »
Timing may be off
Logged
zerodaydave
Enthusiast
Reply #4 on:
May 30, 2017, 03:46:55 PM »
I had this problem with one of my bikes. Compression was good so I checked the timing. That was the culprit.
As others have said: Spark, Compression, Fuel.
Logged
Jimray23
Hot Shot
Reply #5 on:
May 30, 2017, 03:50:08 PM »
When you had spark problems, what did u have to replace?
Jim
1979 kz1000b ltd
stage 3 cams
pod air filters
full rewire
dyna-s ignition
dyna 3 ohm coils
Logged
TwoTired
Really Old Timer ...
Reply #6 on:
May 30, 2017, 05:34:33 PM »
What bike?
And did you dismantle the spark advancer?
Logged
DaSchwartz
Full Member
Reply #7 on:
May 31, 2017, 07:05:19 PM »
howdy y'all!Timing is perfect, however, i just learned about the starter clutch today! had no idea such a thing existed. yet mine has apparently failed! Yay! I just happen have the repair kit. Wish me luck!
Logged
fatmatt650
Part Deux
Hot Shot
Reply #8 on:
May 31, 2017, 07:14:43 PM »
What makes you think it's the starter clutch?
Logged
fatmatt650
Part Deux
Hot Shot
Reply #9 on:
May 31, 2017, 07:17:37 PM »
If it's starter clutch it should still kickstart I think?
Logged
DaSchwartz
Full Member
Reply #10 on:
June 01, 2017, 04:36:19 PM »
when i press the start button and rev it for 9 or 10 times, then release the start button, the motor stops cranking and the starter keeps spinning. has a very fast, like a dry, winding down sound for a second or two, then stops.
Logged
63SSRagtop
Full Member
Reply #11 on:
June 01, 2017, 05:56:50 PM »
I had that problem with the 91 nighthawk and turns out I simply had the coil wires on the packs reversed fired up and scared the crap outta me.. lol
Logged
Jmed22
Full Member
Reply #12 on:
June 01, 2017, 06:15:01 PM »
Sounds like maybe the timing or low compression.
Sent from my Life One X2 using Tapatalk
Logged
Jimray23
Hot Shot
Reply #13 on:
June 01, 2017, 06:48:51 PM »
You may need to pull the starter and clean it.
Jim
1979 kz1000b ltd
stage 3 cams
pod air filters
full rewire
dyna-s ignition
dyna 3 ohm coils
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
