Author Topic: 350f not starting after rebuild  (Read 777 times)
Offline red350
« on: July 09, 2017, 10:16:19 AM »
hey y'all,
a while back my cb350f was losing power and had a lot of noise from the cylinders. after it died on me i took apart the top end to find that i had a broken piston ring. i changed them out, deglazed my jugs, and put the engine back together. it ran with a sputter, and some backfiring. on a test ride, it died on me. i didn't trust the cheap rings that i used so i changed them out again, and now it won't start.
i am getting spark from all plugs/wires, getting gas, and the pistons are moving freely. the timing marks are lined up. **there was a hiccup when the bushing from the cam chain tensioner fell into the engine and was obliterated. i retrieved and replaced it and now i can turn the engine over smoothly. still no start though. any ideas appreciated. please and thanks
Re: 350f not starting after rebuild
« Reply #1 on: July 09, 2017, 11:44:45 AM »
Have you checked for crap in the carb float bowls?
Verified compression?
Did you heed the shop manual warnings regarding the Cylinder cover installation?
Offline red350
« Reply #2 on: July 31, 2017, 07:11:45 AM »
I just checked the compression and I had zero. the gauge literally did not move. when I covered the spark plug holes with my finger I could feel suction on the downstroke.
