Where is a good place to get a mm ruler to adjust my float height?(no printer available) I saw an electric one a Harbor Freight (26 bucks) but wondering where
to find just a plain mm ruler. I took off and have been cleaning,trying the old roundtops I put on the 78ss. I had all four pipes heating up (finally), but overflow leak in number 1.after small adjustments ( floats look good) I popped off just the bowl on centerstand and could see there was only half full. How could it be overflowing with bowl not full?
I tried bending tab each way slightly with carbs attached( just dropping the bowl) about 5 times and either got no heated pipe, or dripping oveflow again. I did read this morning that the overflow tube inside may have a crack,but I think the drip would be much slower. I have read for hours this morning and decided to go get a ruler, take carbs off again and try the correct method ( 26 mm) of setting float.I also wonder if the needle and (seat? how do ya fix/remove seat?) might be the problem, but when I push up on the exposed float with finger, the flow stops. I did see the needle stick just a hair, but with a very slight tap of the rubber end of screwdriver the needle would fall down. So I tried another adjustment, waited for the drip, tapped the carb body lightly but she still dripped. Time to go get mm ruler. I'm learning the correct way is the only way, unless ya get lucky, it's going to either not get gas, or leak. I was happy
after installing all new resistor caps and new plugs yesterday she ran much better right away.Get this carb stuff figured out and I'll be in biz. I also got all my rear lights all working yesterday! I had none before.
I took it up the street to my sons, it felt nice to ride even if it wasn't quite right, it was running and moving! No pops, farts , backfires or smoke even! But noticed the drip when I got there and was reluctant to ride it home, I got a rag from him and set it under the drip and left.I made it home without 3rd degree burns or melted bike.
