Author Topic: Exhaust build  (Read 1862 times)
Offline westhewelder
Exhaust build
« on: August 17, 2017, 09:01:35 PM »
Hey guys, I have have been toying with an idea and I'm curious if anyone has done the same? I'm thinking of building my own stainless exhaust system.
Now I know with cars they tend to promote the same length for header tube but it doesn't seem to be the case with a lot of motorcycles that I see. Now I don't plan on a Dr suess style exhaust system but if I'm making the headers relatively reasonably match would that be an Issue? I'm just not too big of a fan of the megaphone exhaust and would like to do a 4-1 side pipe made to accept a common slip on muffler or so I can run them open or keep it down.
Sent from my SM-T377W using Tapatalk
2011 Kawasaki Vulcan 2011
1969 Honda cb750 (project)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Exhaust build
« Reply #1 on: August 18, 2017, 12:30:59 AM »
They are the same length tubes from head to collector.  Sometimes hard to tell because those creative types are good at making things look like they aren't.
Re: Exhaust build
« Reply #2 on: August 18, 2017, 02:40:06 AM »
It's not that important unless you're trying to get the absolute maximum power out of your engine. The CB750F had unequal length headers for no real ill effect, apart from the obviously ugly bulbous muffler that would grab the ground if you leaned it over during spirited cornering, I threw mine away and replaced it with an RC pipe that was a much better fit.
Get them as close as you can, but unless you're looking for a land speed record, you'll be fine. Cheers, Terry. ;D
Fugly 750 by Terry Prendergast, on Flickr
Offline slikwilli420
  • Master of Disaster
Re: Exhaust build
« Reply #3 on: August 18, 2017, 07:33:22 AM »
I think its bad ass. I have wanted to build and exhaust and swingarm for years now, but have not taken the plunge. The bend kits from Cone Eng are a great place to start but hand bending the tubing is another option.
Offline beemerbum
Re: Exhaust build
« Reply #4 on: August 18, 2017, 07:37:24 AM »
Fugly 750 by Terry Prendergast, on Flickr I learned a long time ago to never throw away some stock part from a motorcycle. Think about all those 300 and 341 exhausts that were replaced by 4 into 1's. On the other hand, I wonder why HD even sells bikes with exhausts. Nobody keeps them
Offline przjohn
Re: Exhaust build
« Reply #5 on: August 18, 2017, 08:20:04 AM »
Plenty of info on the internet on this subject. If you have the capabilities and tools to make your own pipes that is pretty cool and a leg up on most of us, best of luck and be sure to post your work.
Re: Exhaust build
« Reply #6 on: August 18, 2017, 08:39:38 AM »
I can do pie cuts at home I have a bandsaw and a abrasive chop saw I also have a tig welder. Did I mention I'm a welder by trade? I also have a tubing gender at work. The problem is more or less the justification of price.
Sent from my SM-G920W8 using Tapatalk
Re: Exhaust build
« Reply #7 on: August 18, 2017, 10:44:50 AM »
Stainless or mild steel if I decide to use exhaust wrap
Offline jgger
Re: Exhaust build
« Reply #8 on: August 18, 2017, 12:18:45 PM »
You can make the Benda by plugging the ends of the pipe and filling it with silica sand. Then heat with a rosebud torch and bend away. The sand helps to know keep the pipe from kinking.
Re: Exhaust build
« Reply #9 on: August 18, 2017, 12:30:27 PM »
We have a mandrel bender at work if anything I'd just get them to bend 8 u bends and that should be plenty
  • Holy Cow! I'm a
Re: Exhaust build
« Reply #10 on: August 18, 2017, 02:42:08 PM »
Cone engineering sells builder parts.  Collectors, expanders, reducers, etc.
Re: Exhaust build
« Reply #11 on: August 18, 2017, 02:45:25 PM »
Sorry I was going to say 4 u bends that way it gives me 8 90* bends
