Author Topic: throttle cable adjustment  (Read 899 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« on: September 07, 2017, 04:59:35 PM »
i'm not understanding what this "throttle override" business is all about in the owner's manual on pages 49-50.  can anyone explain this?  it's seems redundant.  either your throttle is closed or you are opening the throttle with a slight bit of play between closed and starting to open.
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
Re: throttle cable adjustment
« Reply #1 on: September 08, 2017, 06:12:25 AM »
going once, twice, three times a maybe?
cb750 k6 - ugly
Offline magnum56
« Reply #2 on: September 08, 2017, 08:12:54 AM »
I interpret it as the small amount of play between the fully closed position of the throttle, and the throttle position that first begins to actually cause movement down the line.
Honestly though, I never thought much about it.
'74 CB750K
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: September 08, 2017, 08:48:12 AM »
Oh #$%* the manual has words?!?!   ;D
Maybe something got lost in translation?
Offline carnivorous chicken
« Reply #4 on: September 08, 2017, 08:53:37 AM »
Refer to the manual -- we are not supposed to understand this, but simply take it to an authorized Honda dealer.
Offline evinrude7
  • not a kung-fu
« Reply #5 on: September 08, 2017, 12:54:48 PM »
Thanks for giving me the confidence to ignore this. So my next question is how much play should there be in the throttle? I've got almost a 1/4".
Sent from my LG-H871 using Tapatalk
cb750 k6 - ugly
« Reply #6 on: September 08, 2017, 01:00:41 PM »
 It says there 2 to 4 mm.  . 80 to 120 thou..... .125 thou is 1/8 inch.
Offline Bodi
« Reply #7 on: September 08, 2017, 01:15:19 PM »
The play will change with steering angle, so have some grip play where it is tightest.
The over-ride is, I think, the springed plate on the throttle shaft that lets you crank the throttle and force the cable wheel to turn without forcing the slide mechanism too much.
  • Holy Cow! I'm a
« Reply #8 on: September 08, 2017, 01:48:54 PM »
+1 set cable free play with bars at full lock turn.
Had that issue with a vtx1800.  I set the cables with the bars centered, but it would open the butterflies when turned to the right 😜
Offline evinrude7
  • not a kung-fu
« Reply #9 on: September 08, 2017, 06:47:37 PM »
thank ya
cb750 k6 - ugly
