Author Topic: 1974 cb 550 idle circuit  (Read 1359 times)
Offline detaildawg
« on: September 15, 2017, 11:37:45 AM »
Hey all I hope all is well, I have a question.  I just cleaned out the carbs on the 74 550.  I replaced the air box with K and N pods, I rejetted the main to 105 and the slow jet to 42.  It runs great accept for when we put it on the dyno machine, the number 3 carb clogs up the slow jet and the carb goes full lean at idle in about a minute.  I pulled the float bowls back off and the slow jet is glogged yet again.   It is ONLY the number three carb. Any ideas would be greatly appreciated.
Detail...
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 1974 cb 550 idle circuit
« Reply #1 on: September 15, 2017, 12:20:48 PM »
Clean your fuel system and verify the float/fuel level.  Inspect float valve and seat for damage/wear that would jam the valve shut.
Offline Deltarider
« Reply #2 on: September 16, 2017, 04:04:40 AM »
What model is yours? What carbnumber? The year is irrelevant as it tells us nothing. You could have a sticking float needle and try a fuel additive like Seafoam. Is the vent tube of #3 open?
« Last Edit: September 16, 2017, 04:09:31 AM by Deltarider »
CB500K2-ED Excel black
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: September 16, 2017, 07:38:04 AM »
If it is a 74 it can only be a K as the 550 didn't come out until 75.
If the slow jet is actually clogging then you need to replace all your fuel lines including the ones that connect the 2 pairs of carbs
Offline Deltarider
« Reply #4 on: September 16, 2017, 12:16:13 PM »
How are we supposed to know?
Nonsens. That could mean a lot of unnecessarily work. Slow jets can actually clog by residues of gas that have hardened (lighter fractions having evaporated) and rarely do so by dirt. The 2 pairs of carbs are not even connected, but each pair of carbs has its own fuelline. The fuellines from the tankpetcock to the T-joint that feeds 1+2 should be 18cm and the one to the T-joint of 3+4 should be 30cm. Ideal ⌀ 5,5mm. Guaranteed good flow because no kinking. Inline fuelfilters are to be abandoned. They do more harm than good.
« Last Edit: September 16, 2017, 12:30:06 PM by Deltarider »
  • Holy Cow! I'm a
« Reply #5 on: September 16, 2017, 12:49:13 PM »
Amsoil Quickshot cleaner does handsfree cleanouts rather well.  It won't leave a massive cloud of smutz in the air and you won't have to wait overnight.
« Reply #6 on: September 21, 2017, 07:28:26 AM »
Petcock can have debris issues or the tank.  Need to check the petcock screen and your tank for rust and debris and changing the fuel lines is a good idea on bikes new to you.  Honda oem fuel line is of thinner wall construction and will fit through the carb rack's openings.  Be careful with the T fittings between carbs, they have been broken before.
The screen in the petcock fuel bowl can fail or fall apart on 74's oval petcock mounting a pair of screws to mount.
Offline Bankerdanny
« Reply #7 on: September 21, 2017, 03:32:40 PM »
I meant the 2 carbs, not the 2 pairs.
How would we know what? He says he has a 74 550, there was no 74 550F, there was only a 550K.
People often don't replace the connector hoses when replacing the others because it's a pain in the ass. The clogging issues could be gunk from old gas in the carb itself,  it could also be rubber bits from the old bit between the 1 and 2 carb.
