Honda CB750 K2 Clutch jerk/grab when the clutch is engaged.
I have already fitted new clutch plates and it has made no difference. Clutch adjustment set as per manual. The clutch does not slip and the bike is driving normally, changing gears etc. all seems perfect but when moving off from a stop position in first gear the bike jerks as if the clutch is grabbing or gripping more, it also make a sudden groan type noise. Once moving the bike operates normally in all gear and speeds.
Can anyone advise, any help would be appreciated.
