Author Topic: 76 cb750f, cable routing diagram?  (Read 1091 times)
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« on: November 03, 2017, 05:21:37 PM »
Looking for a cable routing diagram for my 76 for 750?
I'm having trouble with clutch?
Re: 76 cb750f, cable routing diagram?
« Reply #1 on: November 03, 2017, 05:56:22 PM »
I can get it for you Sunday. Shoot me an email or PM then so I don't forget.
Offline CycleRanger
  • No comment about being an
« Reply #2 on: November 03, 2017, 09:10:45 PM »
See if this helps at all.
« Reply #3 on: November 04, 2017, 05:30:29 AM »
So the clutch goes through the gauge mount,behind headlight,then ties to frame by header?
That's kinda what I had? But handelbars movement left or right of center affects cable Movement?
It's hard to get a smooth leave when turning left or right from a stop,as u straighten the bars to center and start out with the clutch ,it kinda binds?
Last night I unhooked cable and lubed,then un hooked from frame and it's smooth,but when I attach to frame so exhaust won't burn it, the cable drags Again?
I'm ordering a new cable and would like to rout it correctly, all Hondas should have a soft smooth clutch when installed Proper? At least all I've ever rode Did!
Need pic of cable on bike through forks and attached to Frame?
Thanks
« Last Edit: November 04, 2017, 05:34:06 AM by 1976cb750f836 »
