Author Topic: In which gear do you reach 60 mph?  (Read 5298 times)
Offline aminemed
« on: January 21, 2018, 11:07:27 AM »
Trying to figure out if my bike settings are good, can you let me know in which gear do you reach 60 mph? 2nd gear, 3rd? 60 mph seems like the sound barrier to my bike. It does not clearly accelerate with the same torque from 0 to 60 compared to 60 to 80 for instance. Bike is a cb 750k2
Offline Gordon
  • 750K1, 550K2
Re: In which gear do you reach 60 mph?
« Reply #1 on: January 21, 2018, 11:28:22 AM »
Depends on how quickly I'm trying to get up to speed.  If I'm accelerating to merge onto a 70 mph freeway I might hit 60 in 2nd gear, but if I'm just cruising up to speed I'll be in 4th or 5th by that time.
« Reply #2 on: January 21, 2018, 12:00:15 PM »
 Another way to ask might be what is your rpm at 60.
 They do like rpm, while accelerating I'm not fond of over revving a 40-50 year old bike but they don't have a lot of torque at low rpm's either.
Offline aminemed
« Reply #3 on: January 21, 2018, 12:06:16 PM »
What do you mean by over revving ?
« Reply #4 on: January 21, 2018, 12:15:36 PM »
Operating in the red zone of the tachometer.  Anything below that is perfectly normal and not harmful.
Have you noticed rise of tach needle without a corresponding rise of speedometer needle?  Like the clutch is slipping?
If not, do a plug chop when you hit your perceived "acceleration wall", and see what the plug deposits tell you (us).
« Reply #5 on: January 21, 2018, 12:33:03 PM »
I tend to merge onto the highway in 3rd gear at bringing it up to 70. At that point I just go right into 5th.  These bikes have very little below 4K RPM and really start cooking between 5-7K Rpm. You can really feel it come on.
« Reply #6 on: January 21, 2018, 12:40:49 PM »
2nd
Offline spotty
« Reply #7 on: January 21, 2018, 02:14:42 PM »
in 1st, but that's on the Vmax so its not entirely relevant, i'm just bragging
i blame Terry
Offline aminemed
« Reply #8 on: January 21, 2018, 02:38:11 PM »
According to the manual 60 mph should be reached in 2nd gear at 7500 rpm that leaves 1500 rpm before red zone to go beyond 60 mph still in 2nd gear. I guess that a bike need to be properly tuned to match these specs
« Last Edit: January 21, 2018, 02:44:35 PM by aminemed »
Offline tlbranth
« Reply #9 on: January 21, 2018, 05:57:58 PM »
4th
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline lowriderbud
« Reply #10 on: January 21, 2018, 06:50:49 PM »
I cruise at 60 MPH in 5th gear at 4400 RPM - this is on a '78 750 F SuperSport with stock gearing.  I can hit 60 in just about all the gears but 1st.  After all, this is a 40 year old bike.
Later, Bud...
Online Stev-o
« Reply #11 on: January 21, 2018, 07:33:56 PM »
I wish I had a 350F, then I could hit 85 in 2nd, like JWilde...
Offline Keith
« Reply #12 on: January 21, 2018, 07:48:02 PM »
Your K2 should easily reach redline in the first three gears, and should reach redline in fourth with enough distance. At that point, About 115 mph. Fifth gear? Maybe on a long downhill :)
« Reply #13 on: January 21, 2018, 11:53:44 PM »
Given about 12 seconds dropped down a mine's vertical ventilation shaft I will reach about 122 mph in any gear you want!  :D  ;D
122 mph being terminal velocity and 12 seconds typically about how long it takes to reach that speed.  You will need at least 1500 feet of free fall for this, else you are not going to reach terminal velocity.
;D :D ;D
Offline aminemed
« Reply #14 on: January 22, 2018, 12:58:08 AM »
12 sec from 0 to 122 or from 60 to 122 ?
« Reply #15 on: January 22, 2018, 01:21:08 AM »
12 seconds starting from zero, dropped in vertical free fall assuming nothing but normal wind resistance/air resistance you will achieve terminal velocity of roughly 122mph.  You will have covered 1500 feet in that 12 seconds.
Offline aminemed
« Reply #16 on: January 22, 2018, 02:42:25 AM »
Are you sure ? Yamaha R6 is doing the 0 - 120 mph in 12.2 sec, i doubt that the CB 750 is as fast..
Offline FuZZie
« Reply #17 on: January 22, 2018, 04:28:11 AM »
I think the Yamaha R6 would do exactly the same. ;)
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #18 on: January 22, 2018, 05:22:09 AM »
You will find that acceleration is on a curve, and that the higher speeds are not accomplished in the same time period as the lower speeds due to several factors, one being wind resistance. Another is the torque of the engine to the wheels at lower gear selection is higher, the torque multiplication factor being naturally more due to the lower gear ratios. When you get into the upper gear selections, your rate of acceleration will diminish due to these factors.
Acceleration from 0-60 can be accomplished in 4 seconds, for example.. now this is just an example... acceleration from 60-120 (the next 60 mph) is quite a bit slower, and would be in the 9 second range... again, just an example, due to the other factors mentioned.
Hope this makes it more understandable, if I understand your original question.
And, the terminal velocity of a falling object is due to mean 'ol Mr. Gravity lol....
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Dunk
« Reply #19 on: January 22, 2018, 08:11:47 AM »
Beat me to it!
Seriously though, I'd guess 3rd normally? 2nd maybe if really hauling the mail or 4th if leisurely cruising? If your 750 has trouble getting over 60 you need to look at possible clutch slip as mentioned, as well as air restrictions, fuel restrictions, dirty carbs, etc. Also check that your timing advancer is returning to initial timing and advancing to full advance. They can stick, and if not advancing it will really hurt power. A 750 shouldn't really slow down in the acceleration department until well past 60 MPH.
Offline Yamahawk
« Reply #20 on: January 22, 2018, 08:28:56 AM »
...and actually, acceleration from 60-80 in a top gear roll on would be around 10 seconds too. Now, if your K2 won't accelerate past 60mph AT ALL you have a more serious problem...
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline MoMo
  • Ride like you're invisible
« Reply #21 on: January 22, 2018, 08:44:29 AM »
Beat me to it!
Beat me too, although like the WildeOne, I hit 85 in second with my Seca 400.  Fact verified my Granny :P
Offline sdefoor
« Reply #22 on: January 22, 2018, 10:05:57 AM »
well if we're just all going to start bragging about 1st gear I 103 in 1st on my R1 lol
Offline Yamahawk
« Reply #23 on: January 22, 2018, 11:36:15 AM »
....as Walter Brennan said in "The Guns of Will Sonnett", ...
"NOooo brag, just Fact..."
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Shtonecb500
    • Youtube profile
« Reply #24 on: January 22, 2018, 08:18:19 PM »
on my 500 I'm getting into second gear after 30mph, shifting into third at 50mph.
