Author Topic: CB550 Lithium Battery  (Read 3849 times)
Offline luke_cb550
« on: February 02, 2018, 05:14:44 AM »
I've painted myself into a corner. My battery box i've built under my seat isn't big enough to get a cheap and reliable AGM battery so I'm looking for a Lithium. I've read some good things on other forums about SSB.
I'm just looking for any advice regarding the specs of this battery:
http://www.ssbpowersport.com.au/Products/ProductList/tabid/241/mode/details/pid/616/Default.aspx
I know the Stock battery has 180CCA and 12Ah. This Lithium has 190CCA. I have converted all incandescent bulbs to LED with the exception of the headlight (H4 - 60W). I am also running a Ricks reg/rectifier. I will keep the kick starter but also use the electric start from time to time.
Do you think I would have any problems?
Offline innovativems
    • Innovative MotoSports
Re: CB550 Lithium Battery
« Reply #1 on: February 02, 2018, 06:30:26 AM »
Rick's now has a r/r that has a lower charging cut off to use with lithium ion.  I don't see a problem as long as it's dialed it and pops off fast.  But you always have kicker to fall back on.  I run a 120cca battery on my rc51 and does the job like a champ.  The stock one was about 180.
Personally I love speedcell batteries.  The quick disconnect is great and the cells are wrapped in a fire retardant material should things go bad
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline luke_cb550
« Reply #2 on: February 02, 2018, 04:29:02 PM »
I only have the standard Ricks reg/rec. What do you mean by dialed in and pops off fast?
Offline crazypj
  • I'm brill, me
« Reply #3 on: February 02, 2018, 04:44:33 PM »
Lithium batteries don't like being over or undercharged and can catch fire. Ask Boeing what happens when you can't figure out 'what went wrong'
When a company with billions in backing take a year or two to figure things out it kindea makes me want to stick with AGM  ;D
« Reply #4 on: February 02, 2018, 08:11:11 PM »
As in timing and carbs are adjusted correctly and bike fires like it should.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline b52bombardier1
« Reply #5 on: February 03, 2018, 05:24:39 AM »
Uh . . . no, I don't think he was referring to engine timing or carbs.  I think he meant that a voltage regulator for a lithium battery needs to be very responsive to the special needs of lithium batteries.  A lithium battery does NOT like to be overcharged . . . period DOT!!  Yea, I work for Boeing and believe me, that 787 lithium battery problem was embarassing and Samsung should have paid a little better attention with their cell phones.
  I will stick to other battery technology for a while.  No lithium batteries for me and all you need to do is run a Google search to graphically see why.
Rick
« Last Edit: February 03, 2018, 05:26:24 AM by b52bombardier1 »
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline johans
    • corporate leather
« Reply #6 on: February 03, 2018, 08:46:07 AM »
The ballistic ion and the anti-gravity batteries are somewhat different . Ricks mentions just the ballistic and not the anti gravity . It has to do with the discharge rate upon cranking , especially when its cold out. ( see you tube ) . We just finished a 78 750k  with the original Ricks solid state  rec/reg and a anti gravity and it works great. The problems with the ion is if it is being overcharged ( 14.8 ) or discharged ( 11.8 i believe ) the battery is junk, thats why you cannot use the original regulator . I'm sticking with a 12 cell anti gravity on my current build on a 76 750 SS . i have a digital voltmeter on the bikes to monitor charging. Also you need the dedicated charger for the ion battery. I looked into the ballistic but i am sticking with antigravity . I believe it is worth the $$.
« Last Edit: February 04, 2018, 06:14:45 AM by johans »
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
