Well things are slowly going back together, oil tank, battery carrier, breather pot, electrical board and the wiring harmess are all back on, all electrical connections have been cleaned and treated with dielectric grease. Paint has been removed from all ground connections and checked for continuity.
I'm working in sub assemblies like building a model aircraft, so a lot of components are ready to refit but I'm doing it in sequence.
Just got the aircleaner box down to temporarily refit while I fit the breather line from the KO pot, but was not happy with the state of the bolts, so I took it apart and they were a mess, just ordered replacements, Custom Fasteners in the UK can supply zinc plated panhead screws (philips) that match the Honda originals, so I am using those where necessary, the rest of the bolting is polished head SS or chrome were applicable. It may not please the purists but will look good and last longer, all the Honda bolts are going into a container just in case I get a fit of the purist later on in life !
A lot of the more specialised bolts have been made up for me in SS by a guy in the UK who is also a member of this forum, thanks Paul, all engine bolts, side stand bolt, footrest clevis pins, clutch and brake lever pivot bolts, headlamp bolts (CB750F) and they look great.
Just put the footrests back together and will be fitting them today.
Cheers
Den
