Author Topic: need exact position of tank stripping  (Read 1376 times)
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
« on: February 25, 2018, 05:41:35 AM »
Hi,can't find info or stencil for decal on cb750 k1 black flame on gas tank...i go to paint shop tomorow.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: need exact position of tank stripping
« Reply #1 on: February 25, 2018, 07:45:31 AM »
if folks could add this to the faqs from unmolested original tanks that would be cool (unless already there and i can't find).  does this help bowswell?  http://forums.sohc4.net/index.php/topic,62061.msg676325.html#msg676325
cb750 k6 - ugly
Offline Bowswell
« Reply #2 on: February 25, 2018, 08:02:18 AM »
Something like this.
Offline Dunk
« Reply #3 on: February 25, 2018, 03:55:34 PM »
On my K1 with Yamiya tank the stripe is 97mm at center, as measured from top of stripe to the edge of the fuel filler neck directly above.
The rear point of the stripe is 96mm directly up from the lower rear corner of the tank.
The front lower corner of the stripe is 153mm directly above the front lower corner of the tank.
The front vertical edge of the stripe is 18mm measured straight back from the front edge of the tank at the raised seam/lip.
I measured these using a piece of nylon web/strap laid on the tank, marked that, and measured distance with a caliper. So the measurement is with the contour of the tank as though it were flat.
Offline Dunk
« Reply #4 on: February 25, 2018, 03:57:13 PM »
Offline Dunk
« Reply #5 on: February 25, 2018, 03:57:49 PM »
Offline Dunk
« Reply #6 on: February 25, 2018, 03:58:28 PM »
Offline Dunk
« Reply #7 on: February 25, 2018, 03:59:09 PM »
Offline Dunk
« Reply #8 on: February 25, 2018, 03:59:54 PM »
Offline Bowswell
« Reply #9 on: February 25, 2018, 04:10:33 PM »
Cool!tank you very much.
