Hi guys
Another topic on the proper tuning for a 750 K that is not stock, with k&n pod filters and a 4 into 1 exhaust instead of 4 into 4. My bike was running too lean, with white plugs.
I've recently upgraded my main jet from the stock 105 to 115 and changed the needle setting from the stock middle, 3rd notch to the 4th notch.
Air screw is set to 1 turn.
However, there no enough throttle response yet. When accelerating from idle and when running in 1st and 2nd gear, acceleration is not very strong.
---> What is a bit weird is that there is a very strong engine sound / noise, but there is no counterparty acceleration / power.
I even thought about making a video so you guys can look at what i'm describing.
I've checked ignition and did the 3000 miles routine maintenance, including a carb cleaning.
I'm now going to upgrade my slow jet from 40 to 42 to give some more fuel when accelerating from idle.
Any opinion or thoughts on the tuning ?
