Author Topic: CycleX carb system and Idle  (Read 1971 times)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« on: January 07, 2007, 06:31:15 PM »
Hey folks,
Finally getting the old girl running, and started her up today.
Firing on all 4, prretty damned smooth, however, the old girl idles at about 2.8k
The idle screws don't seem to do much of anything. seriously, like nothing.
What I'm running:
CycleX twin carb setup.
Unkown 4 into 1 exhaust (haven't seen another one like it, actually)
New plugs (autolite 4163, supposedly the d8ea equivalent.)
So, apart from the high idle (and amazingly stiff throttle action, or mebbe I'm a puss), it runs well, revs up to 6 or 7 k smoothly, and has good throttle response.
What am I missing here, as far as idle is concerned?
Only thing I can think of is that perhaps the carbs are not closing completely. I'll have to check that tomorrow.
No.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: CycleX carb system and Idle
« Reply #1 on: January 07, 2007, 06:31:58 PM »
#$%*, meant for this to go in the real forum :/
No.
Offline ElCheapo
    • Anubis Cycle
« Reply #2 on: January 07, 2007, 06:38:06 PM »
Contact them, They will walk you through the goods right on the phone. Great bunch of guys that will help you will all of your questions unlike some sellers.
Contact me for affordable rotor drilling services at $55 each rotor. Same day service on CB750/CB500/CB550 rotors. Next day on everything else.
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #3 on: January 08, 2007, 08:26:11 AM »
Sounds to me like your throttle cables aren't adjusted correctly... possibilities:  Your throttle cables are too short preventing the slides from closing fully or you have the cables hooked up to the carbs incorrectly.  You mentioned that the throttle was stiff, you therefore have something incorrectly hooked up.
Sparty
1972 CB750 K2 Cafe' Style
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #4 on: January 08, 2007, 08:30:33 AM »
Sparty
That's what I'm thinking too. Like I said, runs beautifully cept for idle. No stumbling, racing, anything. Smooth and nice.
No.
Offline Pinhead
  • 1979 CB652-ST
« Reply #5 on: January 08, 2007, 09:10:31 AM »
Do those carbs have a fast-idle setting when it's choked? I've wanted to try the twin-carbs since I saw them a while back. Once you get it up and going the way it should, be sure to post some pics! I'm really looking forward to hearing first-hand how well they work.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #6 on: January 08, 2007, 09:15:18 AM »
I do believe so, yes.
I think everyone who has mentioned that the cables are not adjusted properly are probably correct. When the throttle is closed, there is a good 3/8 to half an inch clearance between the bottom of the slide and the throat of the carb.
No.
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #7 on: January 08, 2007, 09:21:53 AM »
That's probably the problem then. Looking at the instruction booklet that came with my set, it says that there should be a 1mm gap between the bottoms of the slides and the carb bore when viewed from the back side. Have you tried slacking off all of the cable adjustments?
I'm looking forward to hearing how these work out for you too...I haven't installed mine yet.
–Captain Horatio Hornblower
www.thehairynickel.com
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #8 on: January 08, 2007, 09:30:38 AM »
I don't have a day off till next Sunday, so won't be able to till then, but yes, that is what I will do.
No.
Offline heffay
« Reply #9 on: January 08, 2007, 10:21:20 AM »
i would suggest oiling your throttle cable (they sell a great little tool for that)
don't just slack off your cables UNTIL you figure out why it is binding.  if the throttle control is stiff there is something wrong with your routing.
that was a period after routing  ;)
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #10 on: January 08, 2007, 10:28:59 AM »
It doesn't really feel like it's binding. Just feels pre-loaded. WHich makes sense, since it' not being allowed to close as much as it should. the springs are loaded from closed throttle, which should be fixed by adjusting the cables. I mean, it snaps closed easily and very quickly from full throttle.
No.
Offline heffay
« Reply #11 on: January 08, 2007, 10:51:04 AM »
yes... in that case.  it probably is just preload.
carry on  :)
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #12 on: January 08, 2007, 12:51:30 PM »
I put mine together for mockup, and noticed that the carbs' internal springs seemed awfully stiff. I'm hoping that with a grip on the throttle tube it will get a little easier to twist.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #13 on: January 08, 2007, 03:02:54 PM »
Well, these carbs are kinda designed for single carb setups, far as I can tell, so we have twice the spring action. Might see if a 'softer' spring does the trick if this one is too much of a pain.
No.
« Reply #14 on: January 08, 2007, 05:13:27 PM »
Something else has to be available. Sudco would know
Offline mrbreeze
  • Not your average
« Reply #15 on: January 08, 2007, 08:38:02 PM »
I bet you figure it out shortly after you look at it. It should be pretty straight forward.
MEMBER # 257
brimar6
« Reply #16 on: January 08, 2007, 09:44:08 PM »
I think your on the right track. But like elcheapo said give Cycle Exchange a call, they are great to deal with an I'll bet they've seen it all with these carbs.
