Author Topic: 1978 cb750k plug colors  (Read 1047 times)
Offline mrtelec
« on: April 13, 2018, 11:52:10 AM »
Ok, let me start with it is a 1978 cb750k with the pd42b carbs, stock air filter box and new emgo  air filter,I just put on a mac 4into 1 with the baffle Part number (801-1301). I have pulled the carbs and went through them way too many times to say..lol I cleaned them and got the accelerator pump working great, cleaned the main jet and the pilot jet (with a high e .010 guitar string) and did the clear tube method of checking floats. which was a fiasco because number 1 bowl kept having a drip every 4 seconds which had me pulling the bowl off and checking the float height 10 times. arrgh until I found the hairline crack in the bowl from most likely me turning the drain screw in too far. I guess I went just past "a half turn before it breaks" method or trying to get it to stop leaking. The bike starts with choke and runs (its been 40 degrees out) and after warming up it idles fine at about 1700 rpm without choke, I synched the carbs because it wasn't synched after the rebuild. I may mention that the a/f screws were out almost 2 1/2 turns out before. I now have them set at 1 1/2 .I pulled the spark plugs and Number 1 plug is carboned up a good bit, number 2 is less carboned and 3 looks just slightly carboned and number 4 actually looks quite passible. It has only run in the shed where I have been working on it this winter, pretty much at idle to 3500 rpm with revving for about 45 minutes. 20 minutes to do the synchronizing and then 20 minutes for getting the exhaust up to temp to re-torque exhaust claps.it was never under load as far as riding so Is this normal and what should I look at to get all the plugs looking the same.
As a side note I want to thank this forum for helping me with my "journey with this bike, I have made a jig for my carbs, picked up a lawn blower gas tank which have helped with synching making life easier, I have learned allot from reading through here.
Mike
1986 Kawasaki 454ltd
1978 cb750k
1978 skidoo Everest 444l/c e
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: 1978 cb750k plug colors
« Reply #1 on: April 14, 2018, 05:39:19 AM »
I think Hondaman had something about the plugs being black like your in his FAQ's thoughts... something about an o-rink on the spigot side leaking, causing it to suck more gas, you will have to read it to see what I am referring to. If I find it, I will post it for you.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline mrtelec
« Reply #2 on: April 14, 2018, 11:41:14 AM »
Thanks Charlie, I'll go back and read that again. I remember they were still pretty soft and in the right order with the washer and spring, but I can look at them again. On your carbs in the past how much different have your individual carbs differed from 1 to another? I have them all at 1 1/2 as a baseline so I guess I need to adjust them individually starting at 2 then 134 but wondering how much difference will be acceptable.
Mike
1978 cb750k
