Author Topic: GL1000 to CB750 front end swap  (Read 13177 times)
Offline dusterdude
Re: GL1000 to CB750 front end swap
« Reply #50 on: May 12, 2018, 04:10:31 PM »
Ok,according to all balls.the 75/76 gw is a direct swap with our 750's.77 and up are different in some respect but im not sure what the diff is
Sent from my R1 HD using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline American Locomotive
    • sohc4
« Reply #51 on: May 12, 2018, 05:04:20 PM »
I'm trying to figure that out too, as I just bought a '76 750F with a dual-disc GL front end. I've got Comstars front and rear on mine. I'll try to get some pictures of what mine's got going on soon.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #52 on: May 13, 2018, 07:46:04 AM »
Mid run in 77 Honda switches to tapered bearings on the GL1000, I discovered that when I took mine apart to install an All Balls kit. Some research confirmed the factory switch. The bearing size in the kit was identical t the ones on the bike.
