Author Topic: K1 stock airbox  (Read 584 times)
Offline beemerbum
K1 stock airbox
« on: April 23, 2018, 06:20:17 PM »
What is the harm in joining the bottom half of the airbox with the filter to the upper half without the gasket? I am near madness, (a short journey I'm told) trying to get that fershluginer gasket in there. Is there really so much leakage that it would cause poor running. I noticed that on Hackaweek, Dino used no gasket.
Re: K1 stock airbox
« Reply #1 on: April 23, 2018, 06:39:44 PM »
Yeah, once that gasket is messed up, it is a real pita.  I have ran without it too and noticed no issues...probably just need to check that the two halves are not loosening up on ya more often.
Re: K1 stock airbox
« Reply #2 on: April 23, 2018, 06:40:06 PM »
It will still work OK. If the carbs act up (running too rich between 1500-2500 RPM) then you can optionally block off one of the 2 opening inside the box. I'd vote for the front one, as the back one gets less turbulent air. Some have used duct tape to seal off the inside holes: I once pop-riveted a sheet of plastic (0.040" thick) across the front one inside, on a road racer, to get that quiet air from the back.
You could possibly use a large O-ring to fill in the gap: while it is a square cross-section, a large round section will also work. It need not be perfect: I use Walther's Goo glue to hold them in place.
