Author Topic: Can't start in neutral without clutch  (Read 1474 times)
Offline fr33man
« on: April 30, 2018, 12:02:49 PM »
Hi.
My cb750f1 won't start even though the neutral light is on before i pill the clutch. Any advise on where to look to fix it
Big thanks in advance
Sendt fra min BAH-L09 med Tapatalk
Offline flatlander
Re: Can't start in neutral without clutch
« Reply #1 on: April 30, 2018, 12:44:57 PM »
it's a "safety feature": there's a switch in the clutch lever.
Offline fr33man
« Reply #2 on: April 30, 2018, 12:46:40 PM »
But shouldnt The neutral do the same?
Sendt fra min SM-G935F med Tapatalk
Offline flatlander
« Reply #3 on: April 30, 2018, 12:51:03 PM »
no. neutral is a gear position, the clutch lever disengages the clutch in any gear. honda thought it's safest if people can only start while the clutch is pulled.
you can argue it's being over protective - and can remove the switch as many people did before you ;)
Offline Deltarider
« Reply #4 on: April 30, 2018, 12:58:16 PM »
Mine has the safety feature but also starts in neutral.
CB500K2-ED Excel black
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: April 30, 2018, 02:23:12 PM »
My F1 turns over and starts in neutral without needing to do anything with the clutch.
I wonder if your neutral switch needs some adjustment even though it is turning on the light.
Offline Bodi
« Reply #6 on: April 30, 2018, 06:37:40 PM »
There are a couple of safety systems used. One is just a diode between the neutral switch wire and the clutch switch wire, the other is a more complicated electronics module. Either way the neutral switch allows starting through the safety unit, the clutch switch directly connects to the solenoid and is the "master" starter enable. If it's the diode kind, replace it (a cheapo commodity diode is fine, don't spring the $$$ for an OEM one); the SSU module is not so easy to repair. Or bypass it and remember not start the motor in gear with clutch engaged.
