Just read "Engine is off center to the frame" thread and had to ask.
Hondaman said the post 1975 models have a rear wheel offset to the left but didn't say how much of an offset. I am in the process of lacing the rear wheel on my CB750K8 and would love to know how much I need to move the wheel to the left. (yes it would have been smart of me to measure before I took it apart, sadly I didn't
) Will send Hondaman a PM if no response here but thought I would try this first so others could share in the learning.
I hope I can describe this adequately:
When viewed from the rear of the bike:
The offset for the rear wheel is such that the center of the spokes is 44mm to the left of the (machined) face of the brake's drum.
So...if you have the wheel in the wheelstand, face the brake drum to your right, and drop a string (or long straightedge) across the faces of the drum's machined edge and set the center the rim to your left by 44mm. This is why you sometimes see those weird-looking, spindly offset tools hanging from the axle of the alignment jigs...
