Pretty much every bearing made has the part number etched/punched/engraved on the side. The number is probably a 6400 series (6404, 6405... whatevs), and any bearing shop will sell you an excellent replacement. All Balls bearings have no magic, they use the same quality as you find at Harbor Freight. A "name brand" bearing like FAG or NTN will cost maybe a bit more.
If you don't have the original, measure the outer bore, shaft, and thickness (depth of the outer bore for the bearing)... check a 6400 series spec sheet and the right one will be obvious.
Get double sealed bearings, not the single shield ones Honda used. Yes, you get a tiny bit more friction... but the grease stays inside so they will last the rest of your life and beyond.
