Author Topic: Man Cup race this weekend @ Dragway 42, Ohio  (Read 5326 times)
Re: Man Cup race this weekend @ Dragway 42, Ohio
« Reply #25 on: July 18, 2018, 08:11:15 PM »
I have never understood racers that don't black a few spare parts.
 You pay  50 but or more to race, and you get sidelined for sometimes simple pieces  it a piece that is far less than 50.00
 Worse yet when you know they have the spares, and can't bother  to take them along.
Offline POPS 911
« Reply #26 on: July 19, 2018, 09:44:10 AM »
Mike the GS1150 racer has a bracket bike Pro ET. and does not know if it will run 9.40 or 9.70s pass to next pass. If this battery gets low it turn off the MSD box and the motor dies..... he works for JEGS and can tell you every special thing about his battery = it takes two hours after a pass for the battery tender to quit flashing, they will not wait in the lanes for you to come back when THEY are in the ROUND ROBIN end of the day racing = you-all come back means fuel up and get back in place or you lose. that racer had to much static pressure on his lock up and killed the engine when he let off the button [ I asked did you mess with the set up = NO BUT AFTER HE TOOK 3 SHIMS OFF the 60 foots improved and he ran 9.40 ]...... man cannot leave the set up alone = FASTER-FASTER-FASTER . I helped him one day at our home track and the same bike with my set up ran 9.19 HE TUNED IT UP AND RAN 9.70S
Offline dragracer
  • CB750F Dragbike
« Reply #27 on: July 19, 2018, 02:58:57 PM »
A proper clutch set up is the only way a lockup will work. It all begins with static pressure as you know. Maybe he will listen to you next time Pops. By the way. it shouldn't take longer than 10 minutes to get a lithium battery back up to full charge with the correct charger.
Offline POPS 911
« Reply #28 on: July 23, 2018, 08:58:25 AM »
Frank: His special BATTERY is some kind he found on line = lighter, smaller and one pass and your done for a hour or more charge time w/battery tender. KISS is the thinking I like to go with and when you race a bike with bars, box, auto shift, two step, FBG carbs and all motor ....... and you should remember to put it back in 1st. gear after the burn out.
But what do I know as my 1981- 400cc Hondamatic has none of these tools to help me get a better light so I have to live with a .06 or better to have them run me down [ lessons I learned years ago watching Chad Isley take the best down on his  SOHCs 750cc Hondamatic at IDBA.]
POPS BK911
Offline dragracer
  • CB750F Dragbike
« Reply #29 on: July 23, 2018, 02:28:41 PM »
No doubt simple is better Pops. The more electronics you run, the higher the draw on the battery. I always go for overkill on my batteries. The current lithium batteries on the market allow you to pack big power in a small package, but there are some batteries that are not up to the task. Sounds like your buddy needs either an Anti-Gravity battery or a Ballistic. I just bought a Scorpion brand battery for my project F. It has the best price and more CCA than the comparably priced brands I mentioned above. Its a tad bit wider but only a few ounces heavier than the 16 cell Anti-Gravity I run in my onboard start, high compression 1327 KZ engine.
POPS BK911
