Author Topic: Voltage drop at Key Switch  (Read 7530 times)
Offline Staypuff 68
Re: Voltage drop at Key Switch
« Reply #25 on: August 10, 2018, 10:34:12 AM »
The voltage at the battery was 12.63 to begin with, key off.
With the jumper wire to the white field wire  the volts at the battery was 12.23.
Key on 11.90 at the battery and on the white wire.
Engine running the volts stayed the same.
Thats is when I saw the smoke and smelled burning plastic and the regulator was VERY hot to the touch.  So it looks like I will have to get a new one.
The headlight is LED, I have checked the voltage with and without it connected and there was no change to the voltage. The RPM is a best guess for now until I can get a tachometer hooked up, the bike doesn't have one.
« Reply #26 on: August 10, 2018, 09:42:25 PM »
What?? Where did the smoke come from?? Where was the regulator VERY hot to the touch? If it was the resistor on the back of the reg, it's normal for it to get hot, but not so hot plastic burns or smokes.
« Reply #27 on: August 11, 2018, 09:05:40 AM »
I've smoked a rectifier before but never a regulator.
Offline Staypuff 68
« Reply #28 on: August 11, 2018, 01:22:16 PM »
The regulator was very hot to the touch, the smoke and smell came from the coil on the back of the regulator.
« Reply #29 on: August 11, 2018, 02:02:07 PM »
That wire wound resistor is something like a 30 watt dissipator, or more.  And, in normal operation dissipates 15 W max.
Have you measured the field coil resistance?  S/B about 5 ohms (550)  0r 6.8 ohms if 750.  If that white wire has lower resistance than that, it would explain the overheat,  (or if the white branch is shorted to ground).
I think you have have wiring issues.
