Author Topic: Clutch issue 78 750 F.  (Read 623 times)
« on: August 18, 2018, 10:11:28 AM »
 Just installed a rebuilt 78 F  motor into my 74.
 When I first rode it , put it in gear and it UUuurkkked and stalled.... on or off. Felt like a Barnett racing clutch.. , had to slip it or stall.
 Next day rode to town  6 miles all fine, then it sat 2 hours. When I got on it to ride home clutch was easily slipping.... babied it home.
 Checked the clutch, at locknut, no freeplay. Reset it,gave it a bit of clearances locked the nut.
Now it felt more like a normal clutch with  stronger springs.
 Yesterday I ride, put on about 10 miles  park it,  for 7 hours. Started it up and ran it a few minutes during that time m but did not put it in gear.
 Went to leave, same slipping problem..
 Now I can see it may ge running in a bit and needing an adjustment once, but this has me stumped.
 Any ideas or anyone had this happen? Very strange...
Offline jgger
Re: Clutch issue 78 750 F.
« Reply #1 on: August 18, 2018, 10:52:31 AM »
Just a thought Frank, but could the end be getting ready to pull off the cable?
« Reply #2 on: August 18, 2018, 11:42:04 AM »
Lifter plate bolts backing off?
« Reply #3 on: August 18, 2018, 11:55:47 AM »
I have had an ear break in use, made it slip as you made it work hard, higher revs.  This slips at every RpM
 Have not checked  yet , but the first time the locknut adjustment on the motor  had gone to zero freeplay.
 If the cable were pulling out of the end  free play would Increase , but clutch would still work.
 I finally looked at a manual , it said back off screw 1/4 to 1/2 turn then tighten locknut.
Which I did today, will test later. When I adjusted the other say I barely backed it off.
« Last Edit: August 18, 2018, 01:42:32 PM by 754 »
« Reply #4 on: August 18, 2018, 12:06:52 PM »
Frank, do the complete clutch adjustment, not jus the cable, before panicing.
« Reply #5 on: August 18, 2018, 01:45:09 PM »
I added above, re adjusted lockscrew today.
 And this is important, left the cover off.   That may do it. First time  I put cover back on m that usually means you got to go in again.,
« Reply #6 on: August 18, 2018, 05:57:35 PM »
Take a peek at the guts and make sure it has all the ingredients of the late model clutch. This clutch thing gets iffy when people start playing/mixing/matching/replacing with the guts.
