Author Topic: Just got back from the dyno  (Read 17327 times)
Offline Old Scrambler
Re: Just got back from the dyno
« Reply #75 on: October 15, 2018, 09:14:08 PM »
It seems to work for me.........although my lobe centers are different and I don't much care if it works below 8,000 rpm ;D ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online scottly
« Reply #76 on: October 15, 2018, 09:27:24 PM »
I watched the video at the start of this thread again, as well as looked at the charts; the dyno pulls are being started at too low RPM for a motor with a peak near 10K. No wonder there is a lean spike when the throttles are whacked open at 3K. ::) I learned to not bother starting pulls below 4K, reaching WFO near 5K. ;)
« Reply #77 on: October 16, 2018, 03:51:39 PM »
I hear you loud and clear brother. It does rip from 7 to 10,000.  ;)
« Reply #78 on: October 16, 2018, 03:59:23 PM »
It initially goes rich from the accelerator pump @3,000 but the way it goes lean instantly after that is interesting (especially in light of the big vacuum drop going WFO). Usually the accelerator pump has a lingering effect but not in this case. I understand what you are saying and that is a good way to approach carbs with no pump. This cam has an interesting effect on low RPM....just listening to the idle tells you that (though you really can't hear it on the dyno).
Online scottly
« Reply #79 on: October 16, 2018, 07:03:12 PM »
My Webers have accelerator pumps. ;) Note the dip in the attached chart at 3000 RPM for the blue run, and then the lean spot, followed by the mid-range dip in the A/F; the mid-range dip is cam related. It's odd that a change of over 2.5 in the A/F at peak HP RPM only resulted in only a 2.2 HP increase?
I started getting some flaky A/F readings, so I pulled the O2 sensor out of the aluminum block, and found it was wet with sooty water, which evidently had condensed out from the exhaust; the sensor has a heater, but it doesn't heat up the block enough to keep moisture from condensing. You might mention that to Rick.
Offline gschuld
« Reply #80 on: October 20, 2018, 06:28:36 PM »
Mike, the head you are using is what you refer to as a stage 4 head correct?
34/28 Kibblewhite 5mm stem valves, heavily ported K head yes?
Do you have flow numbers handy on that head that you would be willing to share?
George
Offline Bill/BentON Racing
    • BentON Racing
« Reply #81 on: October 23, 2018, 06:42:03 PM »
Oh Mike, the old Falicons and crank are still in Purple Rain. ;D
BentON Racing Website
BentON Racing Facebook
« Reply #82 on: October 23, 2018, 06:56:15 PM »
George
That is the valve set up George. I'd have to dig up the figures....If I remember correctly is was 79 CFM @ .400 lift and 10"
Offline Tracksnblades1
« Reply #83 on: October 24, 2018, 09:29:28 PM »
George
I'm thinking 4 of them @ 79cfm each.........that will support 135.88 Horseys......
Just if one can get em all teamed up and hitched to the same sled and all pulling in the same direction......them high strung ones are a hand full.....Well Done...
« Last Edit: October 24, 2018, 09:32:14 PM by Tracksnblades1 »
Age Quod Agis
« Reply #84 on: October 30, 2018, 04:15:30 PM »
George
Thanks! My son disabled the "No Comment" on Youtube so I posted the #' up there. I'll be back on the dyno in the spring to test the 125-70 cam.
« Last Edit: October 30, 2018, 04:54:07 PM by MRieck »
Offline dragracer
  • CB750F Dragbike
« Reply #85 on: October 30, 2018, 04:52:08 PM »
I've got just the package we need for testing that horsepower at the dragstrip. Lol
« Reply #86 on: October 30, 2018, 06:32:35 PM »
Drag racer,
Can you tell us about what we're looking at ( especially them wheels) that's a good horsepower test mule....?
Age Quod Agis
« Reply #87 on: October 30, 2018, 06:37:56 PM »
Damn Frank! yer cheating on the REAL bike... Looks great, get that engine built. I want to see it shredding tiny bits of ring seating surface out the exhaust on that first high compression pass in 3 weeks??
« Reply #88 on: October 30, 2018, 08:03:43 PM »
Mitchell wheels , nice.. I Just picked up a 18x 5.5 myself... quite light. .
Offline dragracer
  • CB750F Dragbike
« Reply #89 on: October 31, 2018, 12:11:12 AM »
Didn't mean start stepping  on Mikes thread. Find more info on mine here.
Drag racer,
« Reply #90 on: October 31, 2018, 03:31:26 AM »
Drag racer,
No worries Frank.....see you in a couple of weeks.
